Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
Location (State/Prov):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Item Condition:
Bronco with 4" lift and 5.8 roller motor
Old 07-27-2012, 06:33 PM
v8only's Avatar
v8only
v8only is offline
Year: 1990
Make: Ford
Model: Bronco
Price: $2000
Mileage: 191000
Color: blue
Private or Dealer Listing: Private Listing
Location (State): CA
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Blue
Engine: 1996 F4TE Roller engine
1990 bronco 190k...maybe 90k, can't tell...I swapped out 1000 miles ago the old 5.0 engine and swapped in a 5.8 roller cam engine from a 96 bronco...before swapping the 5.8 in I put in new clevite connecting rod and main bearings. Engine is mated to an AOD trans which is in great shape. Truck has factory 4.10 gears....4wd works perfect. Rear driveshaft just rebuilt by a shop (u joints) and shaft rebalanced...Truck has thick custom y pipe with primary cat removed and rear cat hollowed out...3" at y to magnaflow cat back exhaust. Blue interior. 4" rancho lift...no lift blocks...dual shocks up front.
I used a 93 computer so it pops codes for an e4od that it thinks should be there but that's not...ideally you should swap in an 87-89 5.8 computer...Other than that it has a bit of a high idle and low fuel pressure...runs and drives anywhere, but i can't floor it. I've just picked up a new fuel pump (brand new fuel pressure regulator) that I'll include. Included also is smittybilt front/rear bumpers (not installed) and all the original 5.0 accessories if you want them so that you can put the smog pump back on if you need smog....I'll also include a three way catalytic converter that you can weld in if you need to pass emissions.
Truck runs and was my DD...I just got a job where I'm driving 40k a year and needed something newer...while it def needs some more stuff done to it, it's solid and has no rust....clean title, current registration for Cali..
This is my best price...I've dropped the price a TON just to push it and get the cash quick to help pay for the other truck I've already purchased.
truck has stock painted black grill on it now
Philster
32
01-31-2018 08:58 PM
88LX5.0H
1978 - 1996 Big Bronco
22
05-24-2013 07:43 PM
KhanTyranitar
Aerostar
08-27-2011 09:29 AM
yomow
03-05-2004 05:55 PM
alk3myst
12-24-2003 06:59 PM
Quick Reply: Bronco with 4" lift and 5.8 roller motor
