87 f-150 4WD Question
I have the same Hub as your pictures My4Ford trucks. Think I'll try to get a junk yard Dana 44. Not having luck uploading my pic using the phone....
My4Fordtrucks - I saw the eBay listing for the Warn hub. I missed out on two that looked like yours that went for $100 each on eBay this Thursday. I should have grabbed one or both.
When looking, what do I look for:
Dana 44
Is left different than right
F-150 or Bronco, I was told that a F-250 is an A-hub???, also, Bronco II's have 23 bits
19 spline
Anything else?
Lastly, my truck's lockouts did not have the base (spacer) connected to the lockout on either side (as you can see from my pictures). Was this a result of the previous owner grabbing whatever he could? I just want to make sure that if I buy the combined piece, like on your truck, that it's the right part. Thx for all your help!
Dana 44
19 spline
Anything else?
It would need to be for a Bronco or F-150. Left and right are the same. Both of yours are broken. The "base" is part of the hub and should be one cast piece as shown in my picture.
At those prices, you might be better off trying to locate the outer stub axles (or entire axle shafts) , spindles and rotors from a junkyard F150 or Bronco.
Additionally, when driving, the hub seems to sound cranky when in FREE. Sounds fine when in LOCK.
shameless
06-30-2016 09:16 AM
MURDOMINO
10-11-2013 03:29 AM
dreadinger
08-01-2009 04:50 AM
