Family 56 rebuild thread.
#63
Received 4,246 Likes
#68
Two more months and still no cab progress.![Cry](images/smilies2/cry.gif)
I was planning on going to the Super Nationals and buying a complete bed but family issues sorta put that in the "no can do" column. I took the Mono springs off the front and put the stock springs back on. I just wasn't happy with how low the frontend was. Now I've gotta find standard front Shocks. I had Monroes on it before but the number on the shock is no longer listed. Guess I'll look into Gabriels.
#70
#74
Seems all the good ones die young John.![Evil Grin](images/smilies2/evilgrin0007.gif)
I got some weld through primer but it’s copper based and smokes like crazy when I try to weld it (was also pretty pricey). What brand of weld through primer did you use? Seems like all the posts I see they are using gray colored primer.
Another question: did you sand blast your cab after you finished installing all your patches?
#75
I mechanically cleaned the areas where I was patching and did sand blast the cab after. There were a few spots that I blasted that looked like they would be impossible to get to after the patches were in place. Where I used weld through primer at my plug welds I scraped the primer off through the holes before welding, seemed to get cleaner welds that way..After I got it all in epoxy primer I sealed all the seams with seam sealer then applied the high build primer ..
