1961 F100 Crown Vic Swap aka Franken Ford
#76
The following users liked this post:
#81
#82
#83
I have a 2009 crown Victoria rear end that I put in my 1961 F100. I am trying to figure out the gear ratio and from what I've found is that's its a set of 2.73 gears. I am having a hard time finding that new set of that gear ratio. I've found tons of 3 73 ratios. am I reading this tag correctly. and if I was to use the 3.73 gears would it be a noticeable change in top end speed. thanks
#84
Given the size tire that you are running, with an automatic OD transmission, at 55mph you'll see around a 500 RPM increase. So, if you're running around 1200-1300 RPM's with you're 2.73 gear, you'll be in the 1700-1800 RPM neighborhood with a 3.73. You would also feel a big seat of the pants gain in acceleration with that gear change. the chassis that I purchased is a 2009 P71 and it has a factory 3.55 locking rear differential in it.
What is wrong with your current rear end?
#85
#86
#87
Just throwing this out there - My '64 short-wide (Fleetside) weighs 4020 on the scrapyard scale (Two different yards, same weight). Mine's equipped with an Aerostar front end, a 351W, small block C-6 and the original dana rear axle with 8 leaf springs, overload coils on the rear shocks and a power bench seat from a buick.
Aerostars are advertised at around 3500 lbs curb weight.
My 01 Crown Vic is advertised at 3908 lbs curb weight.
A '10 Crown Vic is advertised at 4134 lbs curb weight.
I dunno why, I just find specs interesting. Maybe someone can use this data in deciding on how to proceed with their project.
#89
Before you put that in, pull the clutches out and see that you have a steel-fiber-steel-fiber, etc clutch arrangement. Back in the 90's ford would put two steels or fibers back-to-back, can't remember which, to low the clutch efficiency. The trick was to buy a clutch rebuild kit, which are cheap, and re-arrange the steels and fibers so that you have the strongest possible limited slip results. I think you can buy a stronger tension s-spring(aftermarket) which will also help.
