86' F250 rear into a 1949 F3
Send Chuck an email for cost, he's very good about getting back to you! I even emailed him a few times during install with questions and he was quick to help. Here's his website: Chucks Trucks LLC., Ford Truck Parts and Restoration, Chuck's Trucks, Chucks Trucks
Not really any special tools, the old pinion can be a pain to remove. Chuck suggested hanging the rear by the piñon then heating. I used a brass hammer once it was hot and it slid right out. New one I pressed in.
Here's an old thread on the pinon: https://www.ford-trucks.com/forums/1...l#post16219407
You'll also need to remove the ring gear. The manual says to center punch and drill the rivets out... that didn't work so well for me so I milled the rivet heads off and punched them out. The new ring is bolted on. That's really it. The timken has no backlash setting or anything so it's fairly straightforward.
Another thing to consider when keeping the stock Timken is the huge brake drums. I'm not sure any are available if you need new drums.
They also cause you grief with wheel selection which you already had to deal with. BUT..........I think you can swap later brakes on. Double check because I'm not sure.
Get a cost estimate on your 86 axle mods. I paid $120 for my Dana 60 and spent $300 for new brake components including drums, seals and wheel bearings. The diff looked good so just a flush and new oil.
I paid $165 total to shorten both ends of my drive shaft and re-balance. I had to shorten both ends because I also went with a T98 trans. There is a conversion U-joint but, I got lucky and stock U-joints worked. Ya got some options at least. Just have to see what is best cost effective deal for you.
You may want to think about upgrading to disk brakes on the front in which case you can make them match. Many of us that do not live in very remote areas don't run with spare tires anyhow. Good tires, an air pump and AAA should handle any problems that come up in our areas. Somewhere on this forum there is a recent thread discussing this.
Pete has a good point. Most of the front disc brake conversion kits are for the 5 lug wheels.
I thought a lot about going that route. I actually had the 72 F250 Dana 60 lined up on the way to look at the F3 the day I bought it. Must have been a sign for ME to stay 8 lug.
My stock front drums are in good shape now and it stops better than I thought it would. But.......if I ever need drums it's going to be hard to find a good used set.
Ford 9" 1950 F1 project
I cut down and re-tubed one of my bent dirt modified rear ends. The axle length side to side are different. I set the hub faces up to work with really wide rims with a fairly deep dish. Its a lot of work. This photo shows the results of about 200 hours of work new axels and powder coat. The plug in the case is to inspect the ring and pinion. (I hope I never use it)!
George84
09-18-2010 08:27 AM
2001gocougs
10-20-2006 08:38 PM
Supercrewzer76
11-19-2003 04:08 PM
