Mustangking1's 1978 F250 Build
Old Dec 15, 2013 | 09:16 PM
Mustangking1's Avatar
Mustangking1
It was a test run also for the guages, oil pressure guage didnt work upon start up, will fix that next time im inside the dash.
Old Dec 15, 2013 | 10:12 PM
Killgore's Avatar
Killgore
Subscribed.
Old Dec 15, 2013 | 11:07 PM
Mustangking1
Would someone be able to tell me how wide of hose I will need for the aux tank?
I dont want to disconnect it yet since I dont want to get dirt and stuff in my tank with it disconnected. Even if someone had the metal fuel filler neck that attaches to the bed I could use that measurement also!
Old Dec 15, 2013 | 11:09 PM
Killgore's Avatar
Killgore
The oriellys website might have it. Worst case use tape to cover the hole
Old Dec 28, 2013 | 01:08 PM
Mustangking1
Worked on wire wheeling the front part of the frame where there is about 1/2 inch of grease and stuff built up on the frame. Decided to take the front cab mount inspection plate off to take a look inside, found this,
Also does anyone have any info on transcool transmission coolers, my truck has one and I'm looking for info about it.
Old Dec 31, 2013 | 09:05 PM
Mustangking1
Got tires on it today, brand new 16.5x8.75 Firestone Transforce HT.
On the way home I was driving and the engine started running rough, then wouldn't start. Rolled it into a parking lot. Got picked up got some tools and 1 new fuel filter, hose clamps, and a can of starter fluid I got it started again. Drove home. It's running better now then it did before.
I should have listened to the PO when he said I might want to keep a couple spare fuel filters in the glove box.
I almost didn't get it fixed, my local oriellys didn't have the filter, but my local autozone did, thank god.
No pictures.... Sorry
Old Dec 31, 2013 | 10:47 PM
77blue's Avatar
77blue
Fuel filler hose is 2.5" at least on my 1977.
Old Jan 10, 2014 | 08:54 PM
Mustangking1
Pulled the rear window out to replace the seal.
Window out:
New seal installed:
Gonna get the rear window reinstalled on the cab tmrw.
Soon the floor pans will get welded in then alot of action will start.
I have new door seals, carpet, carpet kick panels, dome light lense, floor mats all waiting to get installed.
Old Jan 11, 2014 | 03:28 AM
BIGT94z's Avatar
BIGT94z
Pretty solid base to start from!
Old Jan 26, 2014 | 12:21 AM
Mustangking1
The sliding window didn't work out. Couldnt find the right seal so I bought a solid rear window out of a 1995 f150 to put in. Got that done today.
Old Jan 26, 2014 | 03:09 AM
blue04.5's Avatar
blue04.5
Did your sliding rear window break? New one looks great.
Old Jan 26, 2014 | 08:54 AM
Mustangking1
No, it did not break but I couldnt find the correct seal for it. The seal I bought was for solid rear glass so i just went and bought solid rear window.
Old Jan 26, 2014 | 09:20 AM
Killgore's Avatar
Killgore
I wouldn't pay too much mind to a guys name who is "67CamaroDude" on a Ford Truck forum haha. She's looking better with glass in the rear now!
Old Jan 26, 2014 | 02:06 PM
blue04.5's Avatar
blue04.5
Thanks for the reply, like I say it looks great. I need to get this done to mine, my rear window seal is badly cracked and I like the way the solid glass cleans up the rear of the truck.
Old Mar 8, 2014 | 08:52 PM
Mustangking1
Got new floor pans welded in today, took the 5th wheel hitch unbolted out of the bed, also replaced the radius arm bushings on the drivers side today. Tmrw I will get the holes in the bed filled in from the 5th wheel hitch.
