Will a 2010 or 2011 F250 bed fit on a 2005 F250?
I have a 2005 F250 8-Foot bed and I want to know if I can replace it with a newer model truck bed. I would like to put a brand new 2010 or 2011 bed on my 2005 F250 Truck. Will it fit? Will I have to do any modification?
Let me know asap. Thanks in advance, :-huh |
1 Attachment(s)
Here is a picture of the 2010 or 2011 bed. Can somebody tell me what year this bed is just by looking at this picture?
Attachment 203514 |
Don't know if it's any help but my 2002 F250 bed and my 2011 F350 beds are exactly the same, the bolts to the frame are the same too. I just swapped out my 5th wheel hitch and the bolt holes all went into the same place (give or take 1/16").
Yes, they're the same. The bed pictured would be a 2010 or earlier. The 2011 beds have different fender styling and won't match the front fenders. Also, the fuel door on the 2011 is different, so I don't know if the filler necks will match up the same. All the bolt holes and dimensions are the same though.
that top bed is a 08-10 box...
and it will bolt directly to your truck, but the taillites would require a bit of moddin to make use of.. the reverse lamp is on top from 08+.. were as your 05 has the reverse lamp on the bottom and the factory wiring harness isnt long enuf to simply plug the bulb into the top.. but its a simple case of just adding some wire extensions.. skip the 2011 box as the wheelarch design is different, unless having non-matchign wheelwells doesnt bother you.. |
Just did the 2000 truck with the 2011 bed swap and its not hard at all. The bed bolts are all the same. As for the tail lights, either reuse your old lights and harness, or re use your old harness and the brake light sockets. Then splice in the 2 wires on each side for the newer reverse light pigtails. The fuel filler lines up correctly, but the mounting holes are in a different spot, requiring 3 self tapping screws to correct the issue. The bumper is also plug and play, however the spare tire access hole is located on the other side of the license plate. For the view concerning the newer rear wheel well styles, it looks just fine and pics will be up on this site shortly of the finished result.
Pics of the 11 bed on an 00 truck are posted in my thread showing the possibilities.
Gas filler neck
2002f350v10
Thanks for the pics of your truck that helped alot. Did you need to do anything special for the gas filler to hook back up? Thanks in advance! Tom |
Originally Posted by 1sicksrt8
(Post 9274409)
http://i71.photobucket.com/albums/i1...00830-0949.jpg |
2 Attachment(s)
I just put a 2011 bed on my 2000 F250 CCSB that had a 7.3L and now sports a built Cummins 12v that I use in competition, the filler piping in nowhere even close to fitting. Hoses are about 4" too short and piping isnow pointing over the frame cross brace. Is there a flexx hose available ?
Thanks Tim |
Originally Posted by Mo Smoke
(Post 11712831)
Thanks Tim |
I ended up using low pressure 1-wire hydrolic hose and it made the sweep with no problems and regular hose clamps.
(Post 11968532)
Thank you. |
So I am thinking that an availible 2003 F350 short box will plug and play on my 2001 F350 short box! The old box is shot like oh so many I see. Thats why they're aren't any out there correct? Thanks.
