anyone running meth or water injection?
like it says....tell your stories tips tricks. im interested ! (aka i got 2k to spend money on lol)
Ziggy(Cory) is running meth/water on his truck. He should be on sometime before work to tell about it.
Interested as well.
ditto! subscribed
I am convinced it helps, but i am not doing it ....yet.
i think water alone is what corey is running
Water: Yes 100%
Meth: Use at own risk. Propensity to add extra CCVs. Nitrous in controlled quantities added at the proper time is a safer option than meth. Although Cory will tell you the key to using meth more safely (it's never really 100% safe) is to be able to supply enough volume at a high enough pressure. |
thanks for the help guys, ive been researching a little here and there. hopefully someone chimes in soon
I am running water injection. There is no need to buy a fancy kit. Here's a parts list:
1 - ??? gallon Tank (mine is 1.5 gallon, I refill it about every 400 miles) 250 psi shurflo water pump 6.2 GPH nozzle (this is what I have) 12.2 GPH nozzle for engines with more HP (they are 1/8" NPT) Tee (if you are using 2 nozzles) 1/8" NPT X 1/4" hose barbs Hose barbs that will fit the pump you buy Metal check valve 1/4" NPT F ports 20 feet of 1/4" OD (.180" ID) poly hose a little 1/4" ID poly hose to connect .180" and the 1/4 hose barb Boost switch (0-25 psi is what I have) Wiring Fuse Switches and LEDs |
Originally Posted by kirkharrod
(Post 9261714)
Originally Posted by rat49f6
(Post 9261758)
What did ur set up run u?
Actually, I think it was about $150.
do u have a thread link or a write up you can put on here...maybe some pics :) :)
Do u have a write up or maybe a model number on the pump
Originally Posted by Philip Berardi
(Post 9261881)
Here's the install I did with a kit. I put together a friend's system buying the parts separately and saved about $100. |
