Solenoid Wiring Help
2000 Expy 5.4. 150K+.
I was replacing plug/coil #4 and removed the firewall starter solenoid/relay wiring to get in from the side, but when it came time to put everything back together, of course I had forgotten how the wiring worked! The battery side is obvious with the double lead, but the starter/alt side I'm not sure about. I have a heavy gauge red cable and another black, both with leads meant for the larger posts on the solenoid. The black connects to the alternator and the red goes into the firewall. Do they go on different posts or the same? Here's a shot with both of them on the lower post. Right now I'm only getting a click from the solenoid when I try to crank the engine. When I put the wiring back the first time I had the black cable up on the top post and the red on the bottom. The engine cranked and turned over but then I stopped it after a few seconds and now it won't crank at all. If this was the wrong wire routing could it have messed a component up? Just tried jumping the two posts with the ignition on and heard the other solenoid on the starter click, but that was it. FYI Battery is registering fully charged on the dash gauge and on a trickle charger. The running and cabin lights do cut out when I try to crank it (key to start position). But the headlights remain strong. Starter relay fuse (#21) is intact. Any advice greatly appreciated! |
Update
Found the correct wire routing on this forum via a google image search.
http://www.f150online.com/forums/mem...ement-part.jpg So now I understand that both red and black cables should be on the same post. However, what would prevent the starter from cranking? Could I have damaged something with the miswiring? Thanks. This is a great forum and I'm glad to have found it. |
Expedition 2001
Stater went bad as my burns out when I misconnect black wire (alternator) to opposite post of the relay/solenoid.
Originally Posted by cynestor
(Post 9246028)
ttt
I'm having the same issue with my 99 lightning. Has anyone solved the problem yet? I've replaced the solenoid, starter, battery and wiring harness and I get nothing. It was able to crank one time right after I put the new starter in. It was just enough to get me home and now it won't start. Just one click. however when I did get it to start I got a bad smell with some smoke. When I got home I saw the wiring harness insulation was melted all over the place. So I replaced it and still I get nothing. I can't even jump the solenoid on the firewall with a screwdriver. Nothing happens. I do get some spark when I ground the bottom post to the firewall. But the starter doesn't turn over. Just a lot of sparks. |
Originally Posted by bluestang1724
(Post 16350691)
Originally Posted by alloro
(Post 16350827)
Have you tried starting it in neutral?
When I attach the batter terminals to the actual battery I don't even have that little bit of spark you get when you connect the battery. |
What does the "I" mean on the starter solenoid? My factory one didn't even have a post where this one is located. It's a small post on the left side.
(Post 16351523)
(Post 16351473)
I have. I moved the shifter quite a few times. I'm trying to look for a bad ground or something now.
When I attach the batter terminals to the actual battery I don't even have that little bit of spark you get when you connect the battery. When that happens a voltage spike is induced into the system. The electronic systems have protection built in for spikes and on some basis when the spike occurs you are testing the protection. The same thing is happening when you "ground the bottom post to the firewall." In the world called perfect turning off everything so a spike or spark does not occur is the desired result. Can a system survive those kinds of actions? Sure and most of the time the systems do. However in a oft quoted saying, You are playing with fire. Those that play with fire run a greater chance of getting burned. Use test equipment, wiring diagrams or take the vehicle to a person that has those skills and resources. The original poster fixed his issue when he discovered he incorrectly connected wires. After he discovered the correct routing the engine started. Not saying this is your issue and known the correct wiring is paramount. No one expects any one to know all of the wiring and for that reason a wiring diagram was made. Because mis-wiring ca damage other electrical parts in addition to not solving the original concern. Or you can continue to attempt repairs with out the resources. >>>>>>>>>Action |
(Post 16352175)
On some applications a wire runs from the "I" to the ignition coil to power it during the starting process.
Originally Posted by Action410
(Post 16352681)
>>>>>>>>>Action |
(Post 16354555)
I tried using the "I" instead and didn't get anything. Not even a click from the solenoid
Only cus I am a bit wound to tight, it is a relay not a solenoid.
>>>>>>>>>>Action |
