xjcamaro89 |
08-02-2010 11:35 AM |
Brake pad fell apart
So last week i noticed like a slight vibe right around 55. Then i started hearing a slight squeak while i was going real slow, or slowing down, like "squeak,squeak,squeak" with every revolution of the tire. So i figured id pull the brakes and lube the pins and slides. Well i did 3 corners and then got to the last one the driver side rear, and pull the caliper off and the pad fell out in two peices, the actual pad and then backing. the bonding came apart, the pads have about 1/2 thickness left but they were the pads that were on my truck when i got it. But i think the vibes i was feeling was coming from that pad seperating and dragging and things of that nature. Glad i checked it out!
