identifying model of transfer case
Is there a number cast into the casing or a tag that would tell me the model of it? If so where would it be found? Thanks.
There's a tag on the case just like a differential tag. It will have it on there. Really though you probably have either a Borg Warner 1356 or a Borg Warner 4407. You can tell quickly by just looking. The 1356 has a slip yoke meaning that the rear driveshaft just slides up into it. The 4407 has a short shaft with a flange on it and the rear DS has a flange as well that will bolt up to it.
thank you very much, I will go and look.
hey redman, did u think of a price on that e40d?
Mine is a 4407.
I figured being a 96 and all. The internals are essentially the same. The case is beefier and the rear DS hookup is a little better than the slip yoke style. Seems like I've heard of them leaking.
Originally Posted by redman84
(Post 9161850)
Originally Posted by Diesel_Brad
(Post 9316370)
I have a 1356 with a flange on the back of my 96 not a slip yolk
(Post 9316370)
The case is different to hold the slip seal vs flange. They are 2 different units. :-huh |
Originally Posted by wildstang
(Post 9317490)
Does that have the pto option /cover on it?
So is the 4407 a better t-case than the 1356?
(Post 9161754)
Update Could not find much other than some cases had id tags attached and some used stick on bar codes BW1356 FULL SIZE BRONCO(F-150/250) 1987-96 BW4407F F250/350 1996-98 BW4406F F-150/250/EXPEDITION, NAVIGATOR 1997-UP AXLE INFO- http://lelandbrake.com/images/catalog/006-011.pdf |
Originally Posted by DRRXR
(Post 9319713)
I will do some checking in my cat for some more info and then repost
Update Could not find much other than some cases had id tags attached and some used stick on bar codes BW1356 FULL SIZE BRONCO(F-150/250) 1987-96 BW4407F F250/350 1996-98 BW4406F F-150/250/EXPEDITION, NAVIGATOR 1997-UP AXLE INFO- http://lelandbrake.com/images/catalog/006-011.pdf I would like a definite answer, if possible, if the 350 yoke would fit the 250 shaft. Some have said it would. |
(Post 9322010)
In another thread on the D60 swap I have asked the same type questions and someone said I need to get the yoke from a f350 that had an e4od like mine and they were only in 96-97 years, because the standard trans used a different transfer case. I bought one from a guy and he said it was from a 97 f350 dually that had the pto cover on the case, but I am not sure if that was a standard trans, will need to ask. If that is true then the standard trans transfer case has a smaller out put shaft for the 4x4.
