My first new truck in 10 years
My 2011 F350 is the first new truck I have bought in ten years. After a protracted battle with a very nice but very troublesome 04 F250 6.0, I realized that my work requires a trustworthy vehicle to tow my fiver from job to job. Hence the new truck. After much deliberation and some coaching from Cheezit, I decided to bite the bullet and be a beta tester for the 6.7. So far, I am ecstatic. Almost 3000 miles in less than 2 weeks and I am averaging around 19 to 20 mpg empty and the last fiver pull showed 12.5 mpg. Power is fantastic and the truck exceeds my expectations. The only issue I have seen so far is the ability to collect speeding tickets, even when towing. The truck is so smooth, quiet and powerful it is easy to get above the speed limit. Not busted yet though.
Regards |
Nice goodluck with it..
Originally Posted by rickatic
(Post 9082663)
Regards Sam |
That's excellent news Rictatic...I've been on the fence with a 6.7 and decided I'm not going to Beta test one for now.
Since you refer to your troublsome 6.0 I have a question for you: Do you feel your second catastrophic failure was due to operator error? You were a strong advocate that all the 6.0 problems could be solved by proper maintenance, but I believe you proved to yourself that maynot be the case. What are your thoughts? Again I'm glad to hear the 6.7 is performing well. I'll continue to subcribe to your reports on the 6.7. |
(Post 9082663)
Regards CJ |
Troy,
The second engine ingested an unknown very small piece of metal, about an eighth inch square which lodged in the number 4 cylinder high side intake valve and bent it slightly. I use my truck to tow my living quarters around the country for work. I have been real busy and decided I wanted a new truck. Debbie qualifies for Z plan pricing and the time was right. Regards |
and yet still no broken trucks are comming in. Also no one has traded them back in to the dealer that I have seen.
Originally Posted by cheezit
(Post 9087312)
Yah this truck is awesome. Dealers are selling a lot off them. Ford has said that the 6.7 will be like the legendary 7.3. They are right. And with tons more power an great mileage.
Originally Posted by 150ford
(Post 9089080)
It's a great truck, that's for sure but we have to see how this truck will hold up. I wonder if anyone even has reached 10k miles yet. |
There was a truck in the shop a buddy works at up here in Abbotsford, British Columbia, Canada, that had 14000 kms on it. That would be about 10K miles. He said there had been no problems with anything on this truck. It was in for an oil change. This truck had driven it out from Ontario by it's owner.
(Post 9082663)
Originally Posted by kper05
(Post 9088648)
Was that happening with the 6.4L in 2008 this early into build 1?
Yeah, I use the cruise control all the time when on the highway. I am up to 3300 miles as of today. Not one single complaint. The mileage over the last 1200 miles has stayed at 19 mpg in mixed highway and city driving.
(Post 9091940)
(Post 9091940)
Too bad they don't offer it with a stick anymore.:mad: |
