My first new truck in 10 years
Old 07-07-2010, 02:00 PM
rickatic
rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
My 2011 F350 is the first new truck I have bought in ten years. After a protracted battle with a very nice but very troublesome 04 F250 6.0, I realized that my work requires a trustworthy vehicle to tow my fiver from job to job. Hence the new truck. After much deliberation and some coaching from Cheezit, I decided to bite the bullet and be a beta tester for the 6.7. So far, I am ecstatic. Almost 3000 miles in less than 2 weeks and I am averaging around 19 to 20 mpg empty and the last fiver pull showed 12.5 mpg. Power is fantastic and the truck exceeds my expectations. The only issue I have seen so far is the ability to collect speeding tickets, even when towing. The truck is so smooth, quiet and powerful it is easy to get above the speed limit. Not busted yet though.
Regards
Old 07-07-2010, 02:34 PM
Mike F250 SD
Mike F250 SD is offline
Mike F250 SD is starting off with a positive reputation.
Nice goodluck with it..
Old 07-07-2010, 03:09 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Regards
no pictures? those of us with limited imagination need bigtime help with pictures.
Sam
Old 07-07-2010, 06:08 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
That's excellent news Rictatic...I've been on the fence with a 6.7 and decided I'm not going to Beta test one for now.
Since you refer to your troublsome 6.0 I have a question for you: Do you feel your second catastrophic failure was due to operator error? You were a strong advocate that all the 6.0 problems could be solved by proper maintenance, but I believe you proved to yourself that maynot be the case. What are your thoughts?
Again I'm glad to hear the 6.7 is performing well. I'll continue to subcribe to your reports on the 6.7.
Old 07-07-2010, 06:13 PM
nomorecummins's Avatar
nomorecummins
nomorecummins is offline
nomorecummins is starting off with a positive reputation.
Regards
Even after having a troublesome 6.0, you still decided to go with a Ford. No wonder Ford sells more diesels then Dodge and GM combined. You won't regret it. Even though I own a 2010 6.4 and not a 6.7, Ford learned a HUGE lesson from the 6.0 fallout and was determined to NEVER let it happen again. Enjoy your truck, and when the day comes that you get a wild hair to remove the DPF/CAT and tune it you will not be able to stop smiling...
CJ
Old 07-08-2010, 04:39 PM
rickatic
rickatic is offline
Troy,
The second engine ingested an unknown very small piece of metal, about an eighth inch square which lodged in the number 4 cylinder high side intake valve and bent it slightly. I use my truck to tow my living quarters around the country for work. I have been real busy and decided I wanted a new truck. Debbie qualifies for Z plan pricing and the time was right.
Regards
Old 07-08-2010, 06:18 PM
cheezit's Avatar
cheezit
cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
and yet still no broken trucks are comming in. Also no one has traded them back in to the dealer that I have seen.
Old 07-08-2010, 11:50 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Was that happening with the 6.4L in 2008 this early into build 1?
Old 07-09-2010, 06:29 AM
150ford
150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
Yah this truck is awesome. Dealers are selling a lot off them. Ford has said that the 6.7 will be like the legendary 7.3. They are right. And with tons more power an great mileage.
Old 07-09-2010, 09:55 AM
kper05's Avatar
kper05
kper05 is offline
It's not legendary yet; it hasn't existed long enough.
It's a great truck, that's for sure but we have to see how this truck will hold up. I wonder if anyone even has reached 10k miles yet.
Old 07-09-2010, 12:09 PM
Chep
Chep is offline
Chep is starting off with a positive reputation.
There was a truck in the shop a buddy works at up here in Abbotsford, British Columbia, Canada, that had 14000 kms on it. That would be about 10K miles. He said there had been no problems with anything on this truck. It was in for an oil change. This truck had driven it out from Ontario by it's owner.
Old 07-09-2010, 05:49 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I'd suggest you try using that little cruise control button. That or put a Toyota sticker on it and tell them it was another stuck accelerator.
Yes. When people discovered what the job 1 6.4 got in MPG's, it was easy to find new used trucks with just a few thousand miles on many dealer lots.
Old 07-09-2010, 09:43 PM
rickatic
rickatic is offline
Yeah, I use the cruise control all the time when on the highway. I am up to 3300 miles as of today. Not one single complaint. The mileage over the last 1200 miles has stayed at 19 mpg in mixed highway and city driving.
Old 07-09-2010, 09:51 PM
cheezit's Avatar
cheezit
cheezit is offline
Rick are you sure you not sad because your turck is running right now.
Old 07-09-2010, 09:55 PM
F350-6's Avatar
F350-6
F350-6 is offline
That's great news. That's almost as good as I get at 334,000 miles with a mixture of city highway. Hopefully you pick up another couple of MPG's when you get it broke in.
Too bad they don't offer it with a stick anymore.
Quick Reply: My first new truck in 10 years
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
