weekend projects
I finally got around to working on my truck some and getting some of my projects done.
My truck is a crew cab short bed F250, which I had already converted the front to F350 suspension and D60. I got a full set of springs off a '04 F350 Single Rear wheel 4x4 truck. SO installed the rear springs, blocks, and overloads in to my truck. I actually had all the SD bolts, however I didn't want to buy odd size drill bits that I never would use again, so I bought a 3/4 in bit and new 3/4 in bolts. I drilled out both ends of my springs for 3/4 in bolts, and the front hanger on the truck, and the factory obs spring shackle. I also replaced the shackle pivot bolt as well, all grade 8 of course. I got the overloads on the springs as well, but I still need to pickup up two more of the frame tabs so I haven't bolted those on yet, but I have them. The factory F250 shocks were too short, but I had gathered up some Rancho RS9000 adj. used shocks and installed them, so far it does seem to ride better over bumps and it raised the truck just over 3in. in the rear so I guess 2in. from the blocks and ~1 or 1.25 in. from springs While I was at it, I also swapped my F250 xlt badges for F350 xlt badges that I snagged last week at work. I like it so much better than before, not even that it rides any different, but I hated it sagging in the rear, now its a usable truck again..... Before: http://i758.photobucket.com/albums/x...r/e87c3ba6.jpg http://i758.photobucket.com/albums/x...r/c117dddd.jpg During: http://i758.photobucket.com/albums/x...r/9676f917.jpg http://i758.photobucket.com/albums/x...r/996de478.jpg After: http://i758.photobucket.com/albums/x...r/b44b166c.jpg http://i758.photobucket.com/albums/x...r/384120ff.jpg http://i758.photobucket.com/albums/x...r/f86b272e.jpg http://i758.photobucket.com/albums/x...r/9d925be7.jpg |
Looks great and gave it a much better stance for sure. I am thinking about installing a leveling kit on my 04 to give it a better look too.
I think it's ugly :p lol...
Originally Posted by DRM
(Post 9000563)
You know that the 250 springs are stronger than the 350 springs right?
I like how it looks. Always liked black. |
Originally Posted by Talyn
(Post 9000845)
I like how it looks. Always liked black. Not to mention I removed 235k mile 14yr old worn out springs and put in 85k mile '04 F350 Super Duty Springs with overloads that came from a truck with a higher GVWR than my truck? |
I for one have never understood what he difference in an F250 LWB and a single rear wheel F350 was!
Did you get a 4.11 rear end? |
Originally Posted by Fifty4F100
(Post 9006147)
Did you get a 4.11 rear end? So my truck has all the F350 components with the exception of a rear sway bar, which hopefully I'll get that soon. Justin |
I think it looks good. My truck tastes are a bit more basic, but I always appreciate what anyone else is doing with their baby. I always learn something from reading these threads!
(Post 9000845)
Originally Posted by TNScrambler
(Post 9000899)
Please explain?
Not to mention I removed 235k mile 14yr old worn out springs and put in 85k mile '04 F350 Super Duty Springs with overloads that came from a truck with a higher GVWR than my truck? Congrats on the swap, looks good. When you gonna do the front? |
Originally Posted by Neal 97 250
(Post 9030565)
I believe Willie is talking about the Front springs from an OBS. That would be true. But as you said you are usin '04 springs so... apples and oranges.
Congrats on the swap, looks good. When you gonna do the front? 1 - move spring mounting location ~ 4in. forward of stock 2 - mount a warn 10k winch behind the bumper. 3 - hopefully be able to mount the winch low enough to clear a shorter 7.3 intercooler. so we'll see how the design, studing, scratching my head and drinking beer part takes before it gets done. on another note, I was able to pick up a rear sway bar off a dually today, so now I just need to get the right link kits for the 4wd and I'll slap that on. Oh, and my exhaust is rubbing the passenger side spring, so I need to get on that too. Justin |
(Post 9030565)
