In Texas heat without a starter!
F350 with ABS light on..won't start in heat of day(starter will not engage) until it cools... late eveing or early morning. New batteries..good connections. Any ideas? Bad relay.. solenoid??
sounds like starter or solenoid to me. Why the ABS is on I don't know.
Originally Posted by erichn
(Post 8860267)
Originally Posted by mueckster
(Post 8860311)
Where abouts in Texas are you? I'm about 35 south of Houston.
What year truck? If the solenoid is on the fender wall jump it out if the starter turns ithe solenoid is probably bad.
Originally Posted by megawatt00
(Post 8860953)
Never messed with the starter (yet), but definitely sounds like a bad starter to me. When did they move the solenoid to the starter?
(Post 8861106)
Sorry for this omission..it's 2000 F350 Turbo Superduty
Originally Posted by Izzy351
(Post 8861125)
my '01 is on the starter. Had problems with it not starting and found that the copper post on the solenoid was corrodide green. Becareful when you take the hot wire off the post to clean it. Lots of liquid wrench. I twisted mine right out of the plastic casing. 65.00 for a new solenoid.... Starts like a wet dream.
Actually the 2000 has 2 solenoids,one on the fender and one on the starter,the one on the fender activates the one on the starter
Guess they were trying to eliminate the GM hot starter effect Sometime in '01 or '02 the eliminated the one on the fender |
