Cleaning Brake Dust from rims
The brake dust on my front rims seems next to impossible to remove. Truck is a 10 F150 4x4 Lariat.
What are people using to remove this? I expect to get in and scrub, but don't want to damage the rims as well. Thanks in advance. |
i just use the same soap i wash the paint with and a old wash mit ( i also wash paint first then wheels)
I do the same as Silver.
IMHO, this is the best stuff available (safe and effective).
Any soap and water will work. Never use a 'wheel' cleaner spray. Most will damage the clear coat. The key is not to let the brake dust build up and eat away the coating. If the dust has gotten into the clear, soap won't help and you have a whole nother problem.
Originally Posted by berry1234
(Post 8816645)
Originally Posted by shotgunz
(Post 8816658)
"P21S is a safe, pH-controlled, non-acid, non-lye based detergent that provides terrific cleaning and guarantees not to damage any type of wheel: painted, clear-coated, polished or anodized."
Simple Green diluted 50/50 with water, let it soak for about 5 minutes (don't let it dry, try to do it in the shade) scrub with an old wash mitt and rinse! You can get simple green at any hardware, grocery store, wal-mart, etc. It's in the household cleaners. It has many automotive uses!
Originally Posted by hivoltj
(Post 8816697)
P21S Wheel Cleaner 2 As you know Simple Green runs off and should not be allowed to dry on the wheels. |
How much commission do you get from hawking that stuff here?
(Post 8816748)
It's really simple. I've tried car wash soap, Simple Green (straight and diluted), 'mag cleaners', etc. and nothing works as well as this stuff. Buy it or don't buy it - I really don't care one way or the other. Before: http://i46.photobucket.com/albums/f1...4/IMG_4456.jpg http://i46.photobucket.com/albums/f1...4/IMG_4457.jpg After: http://i46.photobucket.com/albums/f1...4/IMG_4623.jpg |
Originally Posted by beidle99
(Post 8813720)
+2 on the P21S.
I also put a coat of wax (Collinite 845- marine grade) on my clear coated wheels every few months. It helps to prevent the dust from adhering and washes off quite easily. Once year I pull off the wheels and clean, clay bar and wax both the outer and inner rims. |
If you clean them once a week you will only need soap and water.
Let it cook on there for a few months...now you start needing "wheel cleaners" |
Originally Posted by MaszExpy
(Post 8820405)
+2 on the P21S.
