New Member 5th Truck Need New Ideas
I just purchased a 1975 F100 Custome with a 390 for 200 and drove it home the next day i got to tinkerin with it and fixed all my lights, fixed all the hacked wires but now my transmission aint shifting right i beleive its because the transmission rod that is usually hooked to the carb, isnt hooked to the carb. I have alot of vaccume lines unhooked and a rear main seal shot. Im thinking of taking the standard out of a 1991 Ford F150 with a 5.0 out and putting it in just customizing the pedals to work in the old truck. Will the brake booster and brakes lines work?
How you going to hook that tranny to the fe motor.
should be a vac line running to the tranny modulator, hows the fluid level? only thing the kickdown rod does, is downshift when you mash the gas to pass
the tranny shaft is the same but the bell housing is diffrent i have a cast iron bell housing in dallas for a 390, fluid looks good ill check out the vaccume line
http://i68.photobucket.com/albums/i3...0/IMG00003.jpg
http://i68.photobucket.com/albums/i3...0/IMG00004.jpg http://i68.photobucket.com/albums/i3...0/IMG00005.jpg im thinking black and silver with old skool 5 spoke cragers im wanting the body line to be silver and the rest black except for the grill and the top what do yall think http://i68.photobucket.com/albums/i3...0/IMG00006.jpg http://i68.photobucket.com/albums/i3...0/IMG00007.jpg http://i68.photobucket.com/albums/i3...0/IMG00008.jpg http://i68.photobucket.com/albums/i3...0/IMG00010.jpg http://i68.photobucket.com/albums/i3...0/IMG00011.jpg http://i68.photobucket.com/albums/i3...0/IMG00012.jpg http://i68.photobucket.com/albums/i3...0/IMG00013.jpg http://i68.photobucket.com/albums/i3...0/IMG00014.jpg |
Are those two switches to the left of the steering column stock? I ask because I have some holes in the dash in my '75 at about that location.
no they were added by the last owner one works my tail and running lights and the other works nothing
