351 f150 2WD fuel economy on LPG?
Sorry if there is already a million threads on this...
I have rougly calculated that i am getting 24L/100kms (aprox 10MPG) with my '91 351w F150 2WD on LPG. I do drive it extremely hard almost constantly though :S What kind of figures are other people getting? |
i had no idea these things could run on LPG.
oh...
well you can see my 300L lpg tank in the tray http://i533.photobucket.com/albums/e...l/IMG_0065.jpg http://i533.photobucket.com/albums/e...l/IMG_0063.jpg |
Originally Posted by 87Mater
(Post 8261441)
If properly set up for LPG, they also perform well! With my 90 f250 running on dedicated LPG with impco 425 carb, im getting 300 klms to 80 ltrs around town with a lot of stop start driving, but get 350 klms on the open road! Motor has a stage 2 cam, headwork and 10.5 - 1 comp. Runnung 3.7 diff gears with a C6 |
Originally Posted by FireBlue
(Post 8261460)
oh...
well you can see my 300L lpg tank in the tray http://i533.photobucket.com/albums/e...l/IMG_0065.jpg http://i533.photobucket.com/albums/e...l/IMG_0063.jpg You removed your canopy! Looks a lot lighter now!:-D Good to see you on here! You do get good milage though! You mustnt drive it hard enough!:-X20 |
hey man, it is a very rough calculation, i need to do it more accurately, but i doubt i could drive it much harder... :P
So is your lpg system injected of has an air intake mixer? and what does all this mean? haha Motor has a stage 2 cam, headwork and 10.5 - 1 comp. Runnung 3.7 diff gears with a C6 |
(Post 8261479)
So is your lpg system injected of has an air intake mixer? and what does all this mean? haha Motor has a stage 2 cam, headwork and 10.5 - 1 comp. Runnung 3.7 diff gears with a C6 Cant afford to get injected gas setup! Would get way better milage though!:-D What it all means is that it is a little more info to give a better idea why it sucks as much fuel as it does!:-duel1 |
Oh right i see, how much power are you making? What size engine do you have again?
(Post 8261505)
HP, couldnt tell you but it goes better than it did when standard!:-D Here is a pic of the setup. Not the neatest, but a lot less cluttered than the standard injection setup with the gass installed! http://img19.imageshack.us/img19/8976/p2260661large.jpg This is what it looked like before i changed it to gas (LPG) only. http://img99.imageshack.us/img99/240...s2048large.jpg |
oooh shiney bits! so is your carbied or efi?
(Post 8261546)
The 425 impco carb works well with the rpm airgap manifold!:D |
hmm interesting.
in the US regular unleaded is still fairly cheap. it was $2.46 an US gallon kind of off topic but how is the second alt wired up? |
