Door tag decode
Tried to get a picture of my door tag for decoding. Not sure how good it is.
its kind of fuzzy pat.
Originally Posted by FORD RANGER
(Post 8213694)
Okay, 2nd picture taken & sending. Now have to copy from Photo Bucket ( when it finishes sending ) & paste on :-X25. Well, says sending complete. let me see what I get this time. Here comes second attempt.
Any better? |
Originally Posted by 1OldFordMan
(Post 8213748)
Any better? |
what info are you looking for ? just to decode your vin#? hell pat i can do that for ya.
i'm not sure what your after? just PM me with your vin# and i'll help ya.. |
(Post 8213638)
1FT = Ford Motor Co., USA - Ford Truck (Complete Vehicle). D = 5,001-6,000 lbs. Gross Vehicle Weight Rating. F15 = F150 2WD Regular Cab Pickup. N = 5.0 (302) EFI. 2 = Check Digit = FoMoCo use only. M = 1991 / Production Date: 8/90 = Assembled in August 1990. K = Kansas City Assembly Plant. A08556 = Numerical Sequence of Assembly. The rest is kinda fuzzy for 65 year old eyes to make out. :-X15 Some of it appears to be... 133" Wheelbase. F154 = F150 2WD Styleside Pickup / 5450 lbs. Gross Vehicle Weight Rating. BODY Code = Too fuzzy to make out. TRANS code E = E4OD or 4R100, Ford used the same code for both. AXLE Code = 1?N SPRING Codes: C = Front Spring Code / V = Rear Spring Code. TAPE Code (5) = Used by Ford partsmen/body shops to figure out what the hell the stripe kit part number is. It was a b!tch in the old days trying to figure out what the stripes were, cuz there were no codes, a gazillion different types, some weren't pictured. DSO 53 = Kansas City Ford District Sales Office, where the original selling dealer ordered the truck from. If you type the BODY & AXLE codes, I'll decode them. |
ok ....................
Thanks everybody, Jr. you got me good on that one. Just checked the phone, both gone. Don't know what happened to them. Let me check my Photo Bucket & see if it's still there. Just took it this morning, don't know what happened to it.
Okay, still in Photo Bucket. Think this was the second picture. Trying it again.
http://i836.photobucket.com/albums/z...1260213519.jpg |
Here's the other one. Looks fuzzier to me. That would make the other one the second ( newer ) picture.
(Post 8214331)
1FTDF15N2MKA08556
(Post 8215859)
Body BJ4? Axle 1984? 19N My eyes aren't too good either even with my extra set, Add in AAADD & CRS, I'm a real mess.
AXLE 19N: Ford 8.8" Rear Axle / 3.55-1 / non Limited Slip / 3800 lb. Rear Axle Capacity. EXTERIOR PAINT COLORS: YY = Colonial White / If the second code is YN = Silver (The second letter appears to be an N). |
(Post 8216403)
BODY BJ4: BJ = Granite Knit & Vinyl Upholstery / 4 = Styleside Pickup, Bench Seat.
(Post 8216808)
Thanks for the help. Not sure I'd call it silver, little darker. Just curious, the seat I swapped out was cloth. Does that mean it was changed before I got it? 355 gears sounds good. Don't want to mess with that. I was hoping & got lucky this time.
Is there any vinyl on the door panels? The second letter of the tu-tone paint color code seems to be an N, which would indicate silver, but the pic is a bit fuzzy. And as I said earlier, my eyes are 65 years old...the lenses were R&R'd in the 1990's after having cataracts removed, but.... btw: WOW...you've racked up a lotta posts in the three months you've been a member. At this rate...you may pass the FTE member who has the record for most posts typed in a single year. I'm not sayin' who that is, mebbe you can guess. :) |
