Emergency flasher does not work
99 F150 4.6 single cab.
The emergency flasher system is not working properly. When the switch is pressed it may/ may not flash once then stop cold. Trun signals work just file. I can hear/feel a relay under the dash activate for both flashers and turn signals but was wondering if a seperate relay unit is used for the different functions. Haynes manual electrical diagram is no help as it does not show the flasher relay(s). Or is this just a bad multi=function switch problem. Any guesses? Thanks Dialtone |
I would guess multi function switch.
My guess is a bad flasher relay.
Left hand instrument panel on the fuse panel. |
