Flare nuts Tcooler Lines, '96 F150 4x4 with E4OD
Can anyone tell me what flare nuts would have been used to secure cooler lines to an E4OD in a 1996 F150 4x4 with a 4.9L??
This info would be much appreciated |
I'm assuming the line is 5/16"
I had to get mine from the stealership. I can't quite remember if they came from a different year. I have a 95. I'm assuming you are talking about the nuts between the cooler lines into/on the radiator.
i'm installing a separate fluid cooler, so i'm mainly interested in knowing what threads in on the e4od tranny for the lines.
i have some standard flare nuts for 5/16", hope they work and that it's not some weird metric stuff i need to source out elsewhere. |
