Power Loss............Again!!!!!!!!?????
Hey all, I know this has been covered but my searches haven't turned up what I'm looking for.
My '03 6.0L has absolutely no power until it warms up..again. I say again because this happened a few years ago and the new flash took care of the problem right away. The truck runs great after it warms up, around 140F or so. I can turn my tune up and over fuel and it is good from the get go but I hate to do that for no good reason. Thanks, Eli |
stiction might be the cause
Originally Posted by BAF350
(Post 7683642)
My '03 6.0L has absolutely no power until it warms up..again. I say again because this happened a few years ago and the new flash took care of the problem right away. The truck runs great after it warms up, around 140F or so. I can turn my tune up and over fuel and it is good from the get go but I hate to do that for no good reason. Thanks, Eli Sorry to hear you are suffering performance problems. Do you think that the injectors might be malfunctioning? Can you run the codes to see if they come up faulty? I'd like to recommend running a treatment of Hot Shot's Secret through it to see if it will help. It was designed for International to clean up stiction which is the leading cause of injector failure in the 6.0. It was tested and proven safe and effective for the engine. It carries a money back guarantee so there is never a risk to try it. You can find us on the web at www.lubricationspecialties.com Feel free to call us anytime if you have questions 1-800-341-6516 Best Regards, Dan |
