06 expy EB-need adapter for amp?
I am in the process of getting a new head unit for my expedition. It has the premium factory system (amp&sub). An installer told me today that I need to use a separate adapter to turn the factory sub amp on or it will blow within a week. Unfortunately the install company I used to use closed it's doors and I don't really trust this guy. Can anyone verify. I will be installing a kenwood ddx-714 with camera and pac-swijack adaptor - but will be leaving everything else alone for now. They also want $325 for the deck, camera and pac & I guess this adapter (called it a sven4). seemed a little steep to me. Thanks in advance, Mike.
Metra does show a factory amp integration harness, pn 70-5521.
Description Factory amplifier integration harness (Click on part for more details) Product Specifications * Factory Amplifier Integration harness * 2 RCA plugs to mate to aftermarket radio's pre-amp outputs * One 24-pin power plug and one 8-pin subwoofer plug * A 1.5K Ohm resistor can be used on the amp-remote wire to eliminate turn-on pop. Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed. |
thank you for the quick response - I will pick one of thoose up with the harness. I was looking thru PAC's website but could not find anything. Thanks again.
