Ford Truck Enthusiasts Forums
-   2004 - 2008 F150 (https://www.ford-trucks.com/forums/forum24/)
-   -   What I did about my truck cap.... (https://www.ford-trucks.com/forums/840948-what-i-did-about-my-truck-cap.html)
Hummah Zach 04-12-2009 12:07 AM
When I bought my F150 it came with a bed cap, and I hate the look of them so I took it off the day I got the truck but want to keep it for long trips or other times when I may need to keep my cargo dry....
since Im limited on garage space and live in a neighborhood with a HOA (no sheds, no cap in yard) I decided to hang it from my garage ceiling (I have a pretty tall garage)
What I did was buy a hand-crank winch with automatic brake from Harbor-Freight and mount it to a rafter in the attic above the garage then cut a hole in the drywall so the cable could come down. I then strapped the cap to the winch and it is now lifted up and out of the way.
It is directly above the bed so installation/removal of the cap is easy...
Pictures to come soon!
FTE Trigger 04-12-2009 10:31 PM
I had a neighbor that did something similar for his IH scout cap in his garage.
He did admit that it was a bit hairy the first few times of lifting the cap off only b/c the feet that gripped the cap had very little surface area to hold on to. Other than that he thought it was the best thing since sliced bread...
mercman86 04-12-2009 10:57 PM
thats a really good idea! I wish i had a taller garage now!!
jsoko 04-13-2009 01:21 PM
I covered mine with one of those blue tarps when i pulled it up last fall,to keep dust off, big mistake, the fiberglass developed bubbles like tiny blisters. Maybe should have used a sheet
VFR_Man 04-13-2009 01:40 PM
Originally Posted by jsoko (Post 7381188)
...the fiberglass developed bubbles like tiny blisters.
Do you think it was purely chemical, or does your garage happen to get fairly hot? If it was pulled up near an asphalt shingle roof, I could see the radiant heat cooking it pretty good if it was close enough.
jsoko 04-13-2009 01:48 PM
havent had that hot of temps, I think the tarp and moisture had something to do with it
anyway, it must be a good idea to let fiberglass breath
Hummah Zach 04-13-2009 05:02 PM
the bubbling sounds like a moisture thing
I'll try to get pics up soon (I have a bunch of other pics I want to get up as well:D)
Hummah Zach 04-23-2009 06:51 PM
here are the pics finally
http://i260.photobucket.com/albums/i...0418091655.jpg
http://i260.photobucket.com/albums/i...0423091740.jpg
http://i260.photobucket.com/albums/i...423091740a.jpg
http://i260.photobucket.com/albums/i...0423091929.jpg
1975StroppeBaja 04-23-2009 07:41 PM
Nice job! That area above the garage door tracks isn't usually very usable but that is perfect.
I've read about a few folks in the Early Bronco crowd that do this move.
mercman86 04-23-2009 08:06 PM
Nice setup! Thats nice that you have that extra space above the door, i wish i had that kind of room!
Hummah Zach 04-23-2009 08:41 PM
its great! making use of empty space plus its easy to get it on and off the truck. Plus now I have a garage winch :D
