Quick 7.3idi Greasecar question!
Hello All,
I have the (A) supply valve set-up and working smoothly, but because I do not have the Greasecar manual for this engine, I am lost for the setup of the return valve. Can someone with an IDI tell me what lines on the engine to splice into?? Valves have these postions: Normally Open, N. Closed and Common Thanks Dave |
Just call or email Ethan at Greasecar.com
Wow, he had the answer. Thanks Kirk.
P.S. For all who do not know- if you are converting your 7.3 with a feed and return valve system, both injector rail return lines turn into a tee at the back of the farthest injector on the driver's side, it will take a second to see it. DAVE |
Yep Ethan knows his stuff and has always responded promptly to me. I have had good experiences with their customer service.
