Clock Spring
If the clock spring is messed up will it make noise and make it hard to turn? I can hear a noise and it sounds like it is just under the airbag.I have changed the ball joints and front axle joints and it helped a lot but it is still harder than it should be.
A broken clock spring can give you the issues you describe.
http://www.angelfire.com/tx/hootbro/Clockspring.pdf |
Thanks for the reply,I guess I will have to buy a new one and put it in.
