'67 240ci carb diagram?
Hi all,
Does anyone have a scan or link to a diagram of the single-barrel carb used on the '67 6-cyl 240ci engine? (i.e. an exploded view of the carb) Mine's sprung a leak so I need to dismantle and clean it - it'd be nice to have the diagram handy though just in case! Probably a punctured float, or something blocking the float valve - it was sitting at idle and died on me, with gas in places that there shouldn't normally be gas :-) p.s. was this carb used on any other Ford engines for other vehicles? Maybe that'd give me some other places I can search if nobody here has the diagram... cheers Jules |
Originally Posted by JulesR
(Post 6654696)
Hi all,
Does anyone have a scan or link to a diagram of the single-barrel carb used on the '67 6-cyl 240ci engine? (i.e. an exploded view of the carb) Carburetor Factory - Ford F-1 Exploded View ... same basic type, there's just a few extras in that diagram. I took the carb apart and there was 40 years' worth of accumulated gunk in the float chamber and valve assembly. No holes in the float, so I cleaned everything and reassembled and ran things for 30 mins or so with no sign of any problems (so far!). cheers Jules |
Had you not solved it yourself,i would have suggested getting a manual for it,it will come in handy! also a carb rebuild kit should have a diagram for disassembly and reassembly purposes
Originally Posted by iggybob44
(Post 6656249)
cheers! Jules |
