"I" terminal on a solenoid
Is there any good reason to run your coil circuit through the solenoid "I" terminal on a 70's style streetrod rewire? Assuming you use proper guage wire, is it just adding one more potential failure point to use the "I" terminal? Just curious.
'fenders |
The "I" terminal is only activated when the solenoid is engaged (during starting), in order to bypass the ballast resistance in the feed to the coil. This allows for a hotter spark while cranking, thus easier starting, without burning up the points by running them at 12 volts full-time. Hope this answers your question? Steve
So it's a breaker points thing, makes perfect sense.
Thanks 'fenders |
