FORD F-350 2004 Rear axle seal replacement
Hello can any one help me on replacing the rear axle seals on my truck? I am going to do this myself but have not gotten into any yet. Are the rear axles "floating axles"? And is this a big job? What Seals do you Recommend putting back in? Also any torque specs? Any help will HELP alot..
Thanks Mike |
<TABLE width="95%"><TBODY><TR><TD>SECTION 205-02C: Wheel Hubs and Bearings — Full Floating Axle — Dana
</TD><TD align=right>2008 F-Super Duty 250-550 Workshop Manual </TD></TR><TR><TD>REMOVAL AND INSTALLATION </TD><TD align=right>Procedure revision date: 01/02/2007</TD></TR></TBODY></TABLE> <HR>Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups <SUP>https://www.motorcraftservice.com/pu...1527/adobe.gif Printable View (325 KB)</SUP> <META content="Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups" name=tps_proctitle> <TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Special Tool(s)</CAPTION><TBODY><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...36/ST1255A.gif</TD><TD vAlign=top>Adapter for 303-224 (Handle) 205-153 (T80T-4000-W) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...89/ST1869A.gif</TD><TD vAlign=top>Drawbar, Rear Axle 205-098 (T75T-1176-A) (Dana 80) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...40/ST1870A.gif</TD><TD vAlign=top>Installer, Rear Wheel Hub Bearing Cup 205-278 (T88T-1175-C) (Dana 80) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...40/ST2246A.gif</TD><TD vAlign=top>Installer, Wheel Hub Inner Oil Seal 205-445 (Dana S110, S130) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...52/ST1872A.gif</TD><TD vAlign=top>Remover, Rear Wheel Hub Bearing Cup 205-275 (T88T-1175-A) (Dana 80) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...44/ST2508A.gif</TD><TD vAlign=top>Installer, Rear Wheel Hub Bearing Cup 205-100 (T75T-1225-B) (Dana 80) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...46/ST1871A.gif</TD><TD vAlign=top>Remover, Rear Wheel Hub Bearing Cup 205-277 (T88T-1175-B) (Dana 80)</TD></TR></TBODY></TABLE> F-350 https://www.motorcraftservice.com/pu...7/N0031663.gif <TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR><TR vAlign=top><TD>2 </TD><TD>— </TD><TD>O-ring (part of 4234)</TD></TR><TR vAlign=top><TD>3 </TD><TD>1124 </TD><TD>Hub nut</TD></TR><TR vAlign=top><TD>4 </TD><TD>1240 </TD><TD>Outer rear wheel bearing</TD></TR><TR vAlign=top><TD>5 </TD><TD>1239 </TD><TD>Rear wheel bearing outer cup</TD></TR><TR vAlign=top><TD>6 </TD><TD>1109 </TD><TD>Rear hub and rotor assembly</TD></TR><TR vAlign=top><TD>7 </TD><TD>1243 </TD><TD>Rear wheel bearing inner cup</TD></TR><TR vAlign=top><TD>8 </TD><TD>1244 </TD><TD>Inner rear wheel bearing</TD></TR><TR vAlign=top><TD>9 </TD><TD>1175 </TD><TD>Rear hub seal</TD></TR></TBODY></TABLE> F-450 and F-550 https://www.motorcraftservice.com/pu...5/N0031664.gif <TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>4A140 </TD><TD>Axle shaft bolt</TD></TR><TR vAlign=top><TD>2 </TD><TD>1001 </TD><TD>Rear axle shaft gasket</TD></TR><TR vAlign=top><TD>3 </TD><TD>1012 </TD><TD>Wheel nut</TD></TR><TR vAlign=top><TD>4 </TD><TD>2C026 </TD><TD>Brake disc</TD></TR><TR vAlign=top><TD>5 </TD><TD>1244 </TD><TD>Inner rear wheel bearing</TD></TR><TR vAlign=top><TD>6 </TD><TD>1175 </TD><TD>Hub seal</TD></TR><TR vAlign=top><TD>7 </TD><TD>1109 </TD><TD>Rear hub (includes bearing cups)</TD></TR><TR vAlign=top><TD>8 </TD><TD>1240 </TD><TD>Outer rear wheel bearing</TD></TR><TR vAlign=top><TD>9 </TD><TD>1A124 </TD><TD>Hub nut</TD></TR><TR vAlign=top><TD>10 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR></TBODY></TABLE> Removal
OR,
<TABLE width="95%"><TBODY><TR><TD>SECTION 205-02E: Wheel Hubs and Bearings — Full Floating Axle — Ford </TD><TD align=right>2008 F-Super Duty 250-550 Workshop Manual </TD></TR><TR><TD>REMOVAL AND INSTALLATION </TD><TD align=right>Procedure revision date: 01/02/2007</TD></TR></TBODY></TABLE> <HR>Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups <SUP>https://www.motorcraftservice.com/pu...1527/adobe.gif Printable View (512 KB)</SUP> <META content="Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups" name=tps_proctitle> <TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Special Tool(s)</CAPTION><TBODY><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...31/ST1326A.gif</TD><TD vAlign=top>Adapter for 303-224 (Handle) 205-153 (T80T-4000-W) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...44/ST2508A.gif</TD><TD vAlign=top>Installer, Axle Bearing 205-099 (T75T-1225-A) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...44/ST2508A.gif</TD><TD vAlign=top>Installer, Axle Bearing 205-100 (T75T-1225-B) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...50/ST2509A.gif</TD><TD vAlign=top>Installer, Differential Bearing Cup 308-163 (T88C-77000-FH) (use as Hub Inner Bearing and Seal Remover) </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...04/ST2240A.gif</TD><TD vAlign=top>Installer, Wheel Hub Oil Seal (10 1/2 inch) 205-422 </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...10/ST2241A.gif</TD><TD vAlign=top>Remover, Wheel Hub Inner Bearing Cup (10 1/2 inch) 205-421 </TD></TR><TR vAlign=top><TD>https://www.motorcraftservice.com/pu...28/ST2244A.gif</TD><TD vAlign=top>Remover, Wheel Hub Outer Bearing Cup (10 1/2 inch) 205-420</TD></TR></TBODY></TABLE> <TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Material</CAPTION><TBODY><TR vAlign=top><TH>Item</TH><TH>Specification</TH></TR><TR vAlign=top><TD>Premium Long-Life Grease XG-1-C or XG-1-K (US); CXG-1-C (Canada)</TD><TD align=middle>ESA-M1C75-B</TD></TR></TBODY></TABLE> https://www.motorcraftservice.com/pu...4/N0031673.gif <TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>N811648-S100 </TD><TD>Axle shaft bolt (8 required)</TD></TR><TR vAlign=top><TD>2 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR><TR vAlign=top><TD>3 </TD><TD>2C026 </TD><TD>Rotor (single rear wheel [SRW])</TD></TR><TR vAlign=top><TD>4 </TD><TD>2C026 </TD><TD>Hub and rotor (dual rear wheel [DRW])</TD></TR><TR vAlign=top><TD>5 </TD><TD>1A124 </TD><TD>Hub nut (RH)</TD></TR><TR vAlign=top><TD>6 </TD><TD>1A125 </TD><TD>Hub nut (LH)</TD></TR><TR vAlign=top><TD>7 </TD><TD>1239 </TD><TD>Outer bearing cup</TD></TR><TR vAlign=top><TD>8 </TD><TD>1240 </TD><TD>Outer cone and roller</TD></TR><TR vAlign=top><TD>9 </TD><TD>1243 </TD><TD>Inner bearing cup</TD></TR><TR vAlign=top><TD>10 </TD><TD>1244 </TD><TD>Inner bearing</TD></TR><TR vAlign=top><TD>11 </TD><TD>4670 </TD><TD>Slinger</TD></TR><TR vAlign=top><TD>12 </TD><TD>1177 </TD><TD>Hub seal</TD></TR><TR vAlign=top><TD>13 </TD><TD>1A034 </TD><TD>Rear hub assembly (with cups)</TD></TR><TR vAlign=top><TD>14 </TD><TD>1109 </TD><TD>Rear hub assembly (complete)</TD></TR><TR vAlign=top><TD>15 </TD><TD>2209 </TD><TD>Parking brake assembly</TD></TR><TR vAlign=top><TD>16 </TD><TD>390258-S </TD><TD>O-ring</TD></TR><TR vAlign=top><TD>17 </TD><TD>W704709-S428 </TD><TD>Wheel stud</TD></TR></TBODY></TABLE> Removal NOTE: The single rear wheel (SRW) hub and the dual rear wheel (DRW) hub are different in appearance, however, the tools and procedures are the same with one exception: the brake disc can remain attached to the DRW hub if the longer driver handle is used to remove and install the bearing cups and seals. NOTE: A SRW hub cutaway is shown for clarity in this procedure. However, the procedure is the same for the DRW hub.
AND,
Material Item Specification Fill Capacity Premium Long-Life Grease XG-1-C or XG-1-K (US); CXG-1-C (Canada) ESA-M1C75-B — Torque Specifications Description Nm lb-ft Axle shaft bolts 133 98 Rear hub bolts 155 114 Rear hub nut (To set bearings, back off the hub nut 90 degrees, retighten.) 95 24a 70 18 a Maximum torque to rotate the hub is 2.3 Nm (20 lb-in) when the end play is zero. __________________________________________________ ________________________ Material Item Specification Fill Capacity Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant XY-75W140-QL (US); CXY-75W140-1L (Canada) (vehicles with the trailer towing option or 4:10 ratio) WSL-M2C192-A — Premium Long-Life Grease XG-1-C or XG-1-K (US); CXG-1-C (Canada) ESA-M1C75-B — Stud and Bearing Mount TA-27 WSK-M2G349-A1 — Torque Specifications Description Nm lb-ft Axle shaft bolts 109 80 Hub nuta — — a Refer to the procedure in this section. |
I changed the inner seals on my truck last fall. One thing is if the inner part of the seal stays on the truck, just hit it with the rounded end of a ball peen hammer. It will cause the thin metal to spread out and give you enough growth in the diameter to slide it right off...
The bearings looked fine so I just repacked them, I had around 80K on it at the time. |
Great job with the instructions highland61.
Here's a link with some pics of the seal change. https://www.ford-trucks.com/forums/7...ake-shoes.html |
that is real helpful .getting ready to do mine.
Thanks for the detailed information. Are the specialty tools expensive or can i rent them some where?
Originally Posted by mikestoke
(Post 6359293)
You do need a good size hammer and use your old parts with some brass stock to set. or take the hubs and parts into a heavy truck shop....they have the right stuff. . |
Ok thanks I'll let you know how it goes..
Is this a Kit that i will be buying or will i have to buy it all seperate
Does any one know what size the Hub nut is so i can buy the hub nut wrench? I've called the autoparts store and they dont have a clue!! 2004 F-350 SDD DWR 6.0
Thanks Mike |
lisle ratcheting lock nut tool #28000
Thanks again for the detailed info. Got everything changed today, Took about 2 hours. I couldnt of done it without you all!!
Mike |
