Originally Posted by Jason Lewis
(Post 9423209)
Take a pic of that antenna, i had the same problem years ago with the old one!
I keep forgetting to take a picture when its light outside lol
Originally Posted by TexasGuy001
(Post 9424571)
Why would you cut the end off the the antenna? The little ball on the end wont be there and it will look goofy?
http://i68.photobucket.com/albums/i3...ROBBY003-1.jpg
http://i68.photobucket.com/albums/i3...ROBBY002-1.jpg http://i68.photobucket.com/albums/i3...n/ROBBY004.jpg painted the motor for the stang i think its all purty now i know about the over spray im going to let it drive over night and it he over spray with a wire brush |
did the seafoam treatment and changed the fuel filter. seafoam=SMOKE show! hahaha
Originally Posted by 86F150302
(Post 9428679)
http://img840.imageshack.us/img840/3425/001bn.jpg
I keep forgetting to take a picture when its light outside lol Just pull the ball off and put it back on after cutting antenna. |
I just did a transmission fluid flush on my truck, replaced the filter and pan seal.
No that did not fix the leak!!! The leak is really bad. I wouldn't drive it in this state. Please help and read my post. https://www.ford-trucks.com/forums/9...sion-leak.html |
Took out the center counsel in my truck. Going to build my own in a few days.
Also cleaned under the front seat. The seat frame under the center counsel was very nasty! |
went another day without scrapping her out
Originally Posted by greyghost85
(Post 9432037)
Although in truth, it wont be long and my 95 will be scrap. |
Originally Posted by LCAM-01XA
(Post 9428422)
Alex, bolt the spare wheel on the front bed wall, right behind your (driver-side) seat - it don't really obstruct your view in any direction, and it don't really get in the way when it comes to filling up the bed with stuff.
Clay, from what I can see in your avatar pic your spare wheel is actually bolted to the driver-side bed rail in the front of the bed - did you move the wheel from there since the pic was taken? Actually there is an optional factory bracket assembly that puts the spare wheel in that location (on the bed rail), I think it was LMC's catalog that I saw that in...
Oh, and as for my truck-related activities, I finished up the York install today - last night I noticed the belt starts slapping pretty bad when the pressure goes past 50-60 psi, so today I added an idler pulley for it to ride on - worked like a charm, belt stays nice and straight. Now I gotta make an idler for the other side of thee engine, so I can use the factory belt routing for the alternator but without the nasty belt slap that goes with it... |
Here's a quick photo update.
http://i976.photobucket.com/albums/a...k/IMG_1054.jpg http://i976.photobucket.com/albums/a...k/IMG_1095.jpg http://i976.photobucket.com/albums/a...k/IMG_1094.jpg http://i976.photobucket.com/albums/a...k/IMG_1039.jpg http://i976.photobucket.com/albums/a...k/IMG_1040.jpg http://i976.photobucket.com/albums/a...k/IMG_1098.jpg http://i976.photobucket.com/albums/a...k/IMG_1097.jpg http://i976.photobucket.com/albums/a...k/IMG_1096.jpg http://i976.photobucket.com/albums/a...k/IMG_1042.jpg Handles, CB remounted, polished headlights, painted over old bare spots. Sorry for the quickie. Hey Clay and LCAM, you guys have any pictures of your tire mounts? |
Replaced both of the front rusted out spring shackle hangers. I now have all new rear shackles. Next project is to do the rear shocks and mounts - really rusted!
Finished the 86's clutch "up(down)grade" to manual clutch. Its got a replacement bell housing and clutch. Worked fine for the drive to school.
Thinking about going to a ZF5, or ZF6 if I can find one in the BBF setup. Just to get some better RPM and MPGs at highway speed (65 MPH at 3000 RPM). Assuming I can find an adapter, I may try to set up a Strait 10, or Fuller 8 in it. Simply because it would lead to may less RPM, thus way better MPGs, and have plenty of room for increasing torque in the future (pushing 485 ft/lb now which is 100 over stock.) (no, I aint just running my mouth, I'm looking for your opinions on this.) |
Originally Posted by Marine5811
(Post 9433394)
You can actually apply the same idea, only in a bit opposite way - first lean your wheel against the front bed wall and with a sharpie mark on the top rail where one or two of holes line up (may have to rotate the wheel a bit to get them located good). Then take a piece of angle iron that is about as long as the wheel's diameter and slip it inside the top rail and bolt it down to it (one or two 5/16" bolts at each end will be plenty sufficient), then drill some holes through the bed rail and the angle iron behind it - you have a halfton truck that uses 1/2" wheel studs, so drill 3/8" or 7/16" holes. Now, remove the angle iron from inside the bed rail, and weld some 3/8" or 7/16" nuts to its back over these holes you just drilled - I've found the easiest way to weld nuts to something is to use a bolt to hold them tight, when you're done just remove the bolt and the nuts remain where they should be. Finally, paint the entire thing so it don't rust, slide it back in the top rail, and bolt it in at its ends again (make sure you use washers so the bolts don't pull through the sheetmetal over time) - now go to your hardware store and get a pair of 3/8" or 7/16" bolts that are long enough to go through your wheel's lug holes as it's leaning against the front bed wall and threads into those nuts you just welded to the back of the angle iron - as you tighten these bolts they will pull the wheel tight against the bed rail and the angle iron reinforcement behind it. When the wheel is removed all you have is two threaded holes in your bed rail and two looong bolts laying loose, so you can still load the truck big time if you need to. |
had to pull over and shut my truck off, because my throttle kept on sticking. mounted my semi air horn behind the grille. lol
