Vaccum color coding
Anyone know how to interpret the color coding on the vac diagrams under the hood? There about 5 different colors, but no "key" that defines what the different colors represent. All I can figure is that they are for different sizes of line (didn't know if this was a standard anywhere).
Also, anyone know what "SA-FV" might stand for on this vac diagram? (some kind of valve I'm sure) Hell, I might as well throw a few more up here... VRDV? TVS? T REST? V REST? V-CBV? I've come a long way reading and understanding these diagrams, but I haven't quite mastered it... |
Here's a very good site for looking up most of those terms. And it even has links embedded in the descriptions that will explain how some of it works.
Dictionary of Automotive Terms A-Z |
I've never seen a color code for vacuum hoses by either function or size. I just thought they were there as a troubleshooting aid to match the actual hose with the underhood diagram.
SA-FV = Separator Assembly - Fuel Vacuum VRDV = Vacuum Retard Delay Valve TVS = Thermal Vacuum Switch V REST = Vacuum Restrictor T REST & V-CBV are not listed in my '83 Emissions Shop Manuals. |
Originally Posted by Piffery1
(Post 5976834)
BTW: Piffery - thanks for the list... I know I've needed to get a set of shop manuals for my truck - this might be the trigger Franlin - thanks too, I think you forwarded that to me a few months ago, and I lost/forgot about it. saved it this time. |
Vacuum hose sizes, as with many other things, make a difference. If it's too small for the fitting then it can't be forced on or will soon split. Too large and it won't seal or it slips off.
On my vac diagram BV is bowl vent and VCBV (i think) is a vacuum controlled check valve so while running, vacuum does not reduce bowl pressure.
T REST seems to me that it would be a Thermostatic Restriction, like the VCV controlling my distributor advance. Though it's a HD460 you can see my diagram here: IMG_1933 on Flickr - Photo Sharing! JM2c |
(Post 5977020)
My plan was to simply match the hose sizes to the fittings - I obviously would not want to force something that does not fit. I wasnt' sure if there were additional considerations to be had... |
(Post 5976834)
SA-FV = Separator Assembly - Fuel Vacuum VRDV = Vacuum Retard Delay Valve TVS = Thermal Vacuum Switch V REST = Vacuum Restrictor T REST & V-CBV are not listed in my '83 Emissions Shop Manuals. One hose, on the wrong nipple or one cap come of the vacuum tree can cost you a lot of $$$ now that gas is going up to $4,50 a gallon. Yep, the refinery fire about 10 miles from our house had a fire, so they justified raising gas prices up to $4.50. I wish every time I stubbed my toe I could get an extra 75 cents from everyone in California. |
Originally Posted by tommythomasson
(Post 5976154)
Also, anyone know what "SA-FV" might stand for on this vac diagram? (some kind of valve I'm sure) Hell, I might as well throw a few more up here... VRDV? TVS? T REST? V REST? V-CBV? I've come a long way reading and understanding these diagrams, but I haven't quite mastered it... SA-FV Separator Assembly Fuel/Vacuum VRDV Vacuum Retard Delay Valve TVS Temperature Vacuum Switch T REST No Luck V REST No Luck V-CBV No Luck I think Ford re issues these acronyms on weekends just for a laugh LOL. I hope that helps. If you find out the last three let me know and I will put it in the acronym dictionary I am putting together. motdranwod@gmail.com |
'REST' is a restriction.
'CBV' is a combination bypass valve. |
Originally Posted by ArdWrknTrk
(Post 5977489)
I live in the 'toe' of Connecticut.
Asian Spanker is now Old81F100Brown
I also have a tuner BMW, and I buzz past Rice Burners. Thus the Asian Spanker. But my wife said I wasn't being socially responsible. I like my Ford pick-ups, but if I am getting something small it is going to be something that runs the Autobahn. I was driving with my son two years ago on our way to Berlin, we were doing about 120 klicks. Another car passed us on the right proper side and he must have been doing 150 mph. That is the reason they never used to put coffee cup holders in their cars. Take your eye's off the road for one second, at least you wouldn't feel it. Yes my new email is motdranwod@gmail.com Thanks for tracking me down. How are you doing on color coding your vacuum hoses? Did you find good silicon ones? |
Vacuum Hose Colors off the top of my head... They are color coded by purpose, not by hose size or length.
RED: Manifold Vacuum Yellow: Distributor Vacuum Advance Blue: EGR Valve: Port on Carb to PVS. (Ported Vacuum Switch) Green: EGR Valve: From PVS to EGR Valve White: WOT: Wide Open Throttle source vacuum |
Colored Vacuum Hoses in California
I found out why I can't find anything on using colored vacuum hose here in California! Because you will not pass SMOG here in Cali with anything other than black vacuum hoses. Thus the colored stripes down the side of the black vacuum hoses from the factory. I know because I was told at the SMOG center their orders are to run the test and then flunk you (thus getting your $65 to $125) because you have other than black vacuum hoses. They even tried to say the the colored tape I used instead of colored hoses was on there to plug a leak. And tried to take it off! So I flunked because (A) I had a colored hose and (B) there was no cap on one side of my carbon canister.
And the good folks at DMV SMOG said that it wouldn't make any difference on the test, it was just the State of California is trying to get as many old cars off the road to stimulate the economy. So, if someone can come up with a reasonable way to make a colored stripe down a black vacuum hose, I am all ears! I have tried, tape, markers. But I haven't tried paint. It would have to be a painted stripe the long way, just like OEM. |
