Mag-Hytec Transmission pan
Guys, I was thinking about getting a Mag-Hytec Transmission pan for my 2005 Super Duty V10 with the Torque Shift Tranny, question is that is it worth $350 and does it really extend the life on my tranny?
Would like to get one for my 2000 Expedition too. I dont tow with the Expedition even though it has the tow package. Thanks ~Gage~ |
I got my trans pan from these guys: Your Covers
It has been on the truck for 2 years and I have had ZERO problems with it. Cheaper, too. |
Would like to get one for my 2000 Expedition too. I dont tow with the Expedition even though it has the tow package. Thanks ~Gage~ I bought it almost month after owning my new truck! go for three piece set, front diff,rear diff and tranny pan I went that route change out the fluids, too with Synthetic fluid |
Originally Posted by Mark Kovalsky
I can't see it doing anything that will have any effect on the life of the trans.
In race transmissions we run deeper panson the trans that hold more fluid. But not adding the extra fluid. say its a +2 qts pan.so stock pan would hold 5 qts deep pan 7qts we run 4. the deeper pan allows you to run the same or a less whith keeping the fluid lower in the pan.some windage is lost and the fluid heats up faster. We do the same with oil pans for the engine a stock pan with 5 qts may be say 2.5 inches from the gasket rail.and ill build a pan that will hold 18Qts 2.5 iches from the gasket rail.and we'll run 8 in the pan |
Originally Posted by 89CrewCab
(Post 5809495)
It has been on the truck for 2 years and I have had ZERO problems with it. Cheaper, too. Thanks for the link I'll give these guys a call tomorrow. They are pretty close to me too which is always a plus. |
I have gone the "three cover" route. One thing I like is that the covers come ready for a temp probe, which I have in all three. With the extra fluid you will not heat up like you would with the OEM pan. I don't tow, but I've never seen over about 145*F on mine. If you have gages you can wire in multiple probes to the tranny temp gage through a selector switch. That way you can look at any of the inputs on that one gage....
I just have the Mag-Hytec diff cover front and rear on my Super Duty, but I wasnt able to install the front one because it looks like it would hit my track bar. But if I get my truck liftted it would clear it. I do have a temp probe in the rear diff cover. Still on working on getting the Tranny cover, but have to find a job first.
~Gage~ |
Originally Posted by orng1
(Post 6323104)
Wow those guys are good, I ordered it in the evening and got it the next day. I wanted to order both the trans and the diff cover but money is a little tight. |
Whoops, wish I had seen this earlier.
I think I remember Captchas in the V10 forum saying he had done this, and had to chop up the y-pipe to get it to fit. With the cats in it, it's a $1200 piece of pipe I think he said. You might want to search around the V10 forum about that. |
I have a B&M, but BD diesel has one that looks a lot like Mag Hy-tech's. I think BD was a little cheaper too.
1 Attachment(s)
BD Deep Sump Oil Pan
Member Pricing is available. Let me know if you have any questions guys, have a great weekend! Dave :-X25 |
Thats Cool , Very Cool looking
Thanks
-Re usable o-ring gasket -Magnetic drain plug -Pre-tapped for trans temp gauge |
