08 Console... FINALLY!
WOOhooo... I'm so freaking excited.. Now to find time and get it in.. It's sexy LOL
http://www.1badass4x4.com/gallery/al...onsole_001.jpg http://www.1badass4x4.com/gallery/al...onsole_002.jpg http://www.1badass4x4.com/gallery/al...onsole_003.jpg |
yea i def. want to see this installed! it should look awesome.
Just a heads up: When I installed mine it seemed too far forward and too low. I spaced it up about 3/4 of an inch and back about 1 and 1/2 inches, and it is in a sweet spot.
How did you do that? what materials did you use so I can have em on hand incase its too low for me..
I used 4 strips of 1/4 inch thick aluminum about 2 inches long and drilled holes on each end. I then bolted these alum pieces to the console frame using the original bolts and a stack of washers on each one (this gave the rise). I drilled holes on the back end of the straps and used speed nuts and bolts to attach the console ( this brought it back away from the dash). You could probably use just about any material as long as its a type of metal, and you could raise it higher if you replace the orig. bolts with longer ones with the same thread type. I played with it in several configurations and this was the best fit for me. The console is now the same height as the door arm rest, and is confortable on long drives. (went from SA to houston last week)
While that does look sexy, I use my clip all the time :(
Cant wait to see it installed
Nick |
have you thrown her in yet storm?
Here is one one ebay now: http://cgi.ebay.com/ebaymotors/ford-...spagenameZWDVW
That is an awesome looking console, I like my bench seat though, that way someone can sit next to me ;)
LOL, in the time he took pictures of it on the table he could've had it in!!! Hurry up on it! I couldn't resist when I got mine, it came off the UPS truck and I went straight for the tools! Have fun!
I got some 1"x1" 11GA Square Tubing cut in 2" Length.. So I can push it back 2 inches and lift it 1 inch.. Should be much better.. I didn't take into account that I'm tall so my seat goes alll the way back.. I don't like how the jump seat is forward.. Makes it akward. |
