Vacuum Advance/carburetor
Hi,
I joined this site on my friends behalf, he doesn't have a computer, so I'm trying to find out for him certain things he wants to do to his truck. He has a 1986 F150 XL 300ci with a 4 speed. He is in the process of restoring and making some minor modifications to it, he recently replaced the heads, piston rings, bearings, rear main seal, timing chain. What he wants to do now is replace the electrical advance distributor and carburetor with vacuum advance set up. I have done these conversions before but not on a Ford. He wants to keep it a basically stock set up, so the question... stock vacuum distributor for the 300? carburetor, vacuum set up, no electrical plugs? power source, keep the ECU or new connections? Any help on this topic would be greatly appreciated. Joe "joeytunes" Panzarella |
Welcome! :)
It's great your helping out your friend and to get the help you need you want to use the tech forums. Just click on the Forums tab at the upper left and scroll over the list. There is one for his year of truck and another for the 300. Try 'em out and Good Luck! :-headbang |
Originally Posted by joeytunes
Hi,
I joined this site on my friends behalf, he doesn't have a computer, so I'm trying to find out for him certain things he wants to do to his truck. He has a 1986 F150 XL 300ci with a 4 speed. He is in the process of restoring and making some minor modifications to it, he recently replaced the heads, piston rings, bearings, rear main seal, timing chain. What he wants to do now is replace the electrical advance distributor and carburetor with vacuum advance set up. I have done these conversions before but not on a Ford. He wants to keep it a basically stock set up, so the question... stock vacuum distributor for the 300? carburetor, vacuum set up, no electrical plugs? power source, keep the ECU or new connections? Any help on this topic would be greatly appreciated. Joe "joeytunes" Panzarella http://www.performancedistributors.com/forddistributor.htm Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at: https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html |
