Storage of my truck for four/five months???
Hey guys,
I wanted to find out what would happen to my truck if I let it sit for four months without starting it. I have this new job and it requires me to travel to CA and abroad for four/five months. I have parked safe in NJ and it has been sitting there for month and half now already. I also learnt through my family that the batteries were dead. Would it harm the engine, transmission or any thing for the matter? Please let me know ... |
Don't see any harm in it but would make sure to top off the tank and put some fuel stabeliser like diesel klean in it. (If you store it with less thana full tank you will get condensation in the tank). Also make sure the tires ar inflated and disconect the batteries. (after you charge them). If you leave them dead for too long they will sulfate up and be no good. Hope this helps. LPR
Sorry I ment fuel conditioner. It will keep the moisture rounded up and help keep from growing things in your tank. LPR
Thanks
Also I had changed Oil, Filter/s, Differential fluids and Transmission fluids before I put it in storage. Hope this helps, the tank was topped off too. I did remember using Diesel Kleen…nothing else…ffice:office"
Are there any permanent Engine damages that we know of?<O:p |
Absolutely no damage...nothing. Just get the batteries recharged and then disconnect them.
Hey guys another quick question...What happens if I leave it in storage until the year end? The batteries are disconnected; fuel probably is around 3/4th, Diesel Kleen in place, covered and away from elements…
It turns out that I will have to stay in CA and/or have to stay abroad at least till this year end. I know some of you (as well as by buddies) will talk to me about selling it…but I guess I will never do that. 7.3 with 50K is not that easy find these days…plus I have too much invested into and probably a lot more in future…above all, I like that the way the truck behaves and everything… Thanks and appreciate all your opinions and criticism. |
If you can find anybody to drive it occassionally to charge the batts and keep everything lubed it will be fine...
Make sure the coolant is up to spec. Don't want to have a rusty engine when you come back.......
Coolant was replaced last year and has about 15K miles on it since the replacement...all fluids have been changed…oil, differential fluids, transmission fluids etc
