Storage of my truck for four/five months???
Old 05-13-2007, 12:23 PM
Vijay's Avatar
Vijay
Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
Question Storage of my truck for four/five months???
Hey guys,
I wanted to find out what would happen to my truck if I let it sit for four months without starting it. I have this new job and it requires me to travel to CA and abroad for four/five months. I have parked safe in NJ and it has been sitting there for month and half now already. I also learnt through my family that the batteries were dead.
Would it harm the engine, transmission or any thing for the matter? Please let me know ...
Old 05-13-2007, 12:29 PM
LONEPINERON's Avatar
LONEPINERON
LONEPINERON is offline
LONEPINERON is starting off with a positive reputation.
Don't see any harm in it but would make sure to top off the tank and put some fuel stabeliser like diesel klean in it. (If you store it with less thana full tank you will get condensation in the tank). Also make sure the tires ar inflated and disconect the batteries. (after you charge them). If you leave them dead for too long they will sulfate up and be no good. Hope this helps. LPR
Old 05-13-2007, 02:09 PM
LONEPINERON
Sorry I ment fuel conditioner. It will keep the moisture rounded up and help keep from growing things in your tank. LPR
Old 05-14-2007, 11:31 AM
Vijay's Avatar
Vijay
Vijay is offline
Thumbs up Thanks
Also I had changed Oil, Filter/s, Differential fluids and Transmission fluids before I put it in storage. Hope this helps, the tank was topped off too. I did remember using Diesel Kleen…nothing else…fficeffice"
Are there any permanent Engine damages that we know of?<O
Old 05-14-2007, 12:27 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Absolutely no damage...nothing. Just get the batteries recharged and then disconnect them.
Old 07-02-2007, 08:16 PM
Vijay's Avatar
Vijay
Vijay is offline
Hey guys another quick question...What happens if I leave it in storage until the year end? The batteries are disconnected; fuel probably is around 3/4th, Diesel Kleen in place, covered and away from elements…
It turns out that I will have to stay in CA and/or have to stay abroad at least till this year end. I know some of you (as well as by buddies) will talk to me about selling it…but I guess I will never do that. 7.3 with 50K is not that easy find these days…plus I have too much invested into and probably a lot more in future…above all, I like that the way the truck behaves and everything…
Thanks and appreciate all your opinions and criticism.
Old 07-02-2007, 09:25 PM
powerstroke6ltr
powerstroke6ltr is offline
powerstroke6ltr is starting off with a positive reputation.
If you can find anybody to drive it occassionally to charge the batts and keep everything lubed it will be fine...
Old 07-02-2007, 09:46 PM
UcaN
UcaN is offline
UcaN is gaining momentum as a positive member of FTE.UcaN is gaining momentum as a positive member of FTE.
Make sure the coolant is up to spec. Don't want to have a rusty engine when you come back.......
Old 07-02-2007, 10:54 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Agreed. It goes to all of the seals from the engine to the rear end, not to mention the oil in the HPOP. If someone can start and drive it occasionally, that is best. Storage for long term, while not a killer, is not as good. Still, not a killer but not as desirable.
Old 07-02-2007, 10:59 PM
Vijay's Avatar
Vijay
Vijay is offline
Coolant was replaced last year and has about 15K miles on it since the replacement...all fluids have been changed…oil, differential fluids, transmission fluids etc
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
