need advice!
Finally I'm ready to make some mods. to my 99 f 250 5.4 superdutty.I need advice from all you experts.
First I'll regear from 3.73 to 4.30. Also need to know what to do to pull the max possible torque with out affecting hp. I'm planing to swamp headers, wish brand and tipe will be the best. By the moment I need to stay with the stock exaust muffler, but later I'll change it.What do you recomend a chip or a computer programer. I do lots of daily towing and need more power.Basicly these are the 3 things I think should do to improve power, but if somebody knows something better (let me know). Thanks. |
Not having a 5.4 I can't say from experience with that set-up in particular, however, if you re-gear to 4.30 you will LOVE that, next would be the exhaust so it will let it breathe, then programmer and intake, in that order, they all kinda go with each other.... more gas+more air= more power, but if it is restricted (exhaust is stock) your complete gains are not realized, so once your ready to do one, make sure you are ready to do them all.
What size tires do you plan to run?
Oh I almost forgot I want to install limited slip differential ro gears. I want both rear tires have traction.The exaust muffler the less noisy posible.
Man you can ask a big question can't you. What you want to do depends on what you want. You said daily towing, just how much weight? Any off roading how often does a open diff let you down? Are you after gas milage or just the power to spare? Budget is what $1000 or $10000? Planning on getting bigger tires? You may need engine mods only, gear change only or both. I will watch for your answers because I have tried it all on my 2001 5.4L.
