Hpx
Okay dont flame on me here. What are the benefits of having the HPX besides quieting down the motor while idling?
Thanks! |
It also makes it quieter when you're not on it on the freeway. 65mph on flat ground is noticeably quiter.
It helped a bit with cold starts in temps below zero. Idle smooths out much faster after cranking. Do this mod plus put synthetic oil in, and you'll have a truck that will start no matter what it's like outside.
The HP x-over line acts as a shock absorber for the HPO system, since the engine reads the injection control pressure from the driver's side cylinder head, it does not know the pressure in the passenger side, although it should be the same. This line equalizes the pressure and feeds an even pressure to all 8 injectors.
How much do you have to take off to make room to install it? and I assume its pretty simple with good instructioins to figure out on the install.
My son and I installed one last weekend and we didn't have to remove anything. It will be easier if you remove the intake tube to the turbo but we didn't. Whole job took about 30 minutes and that was with a lot of breaks and talking and father/son stuff.
you guys didn't have any problem with leaks after installing the HPX? And which one did you use?
Hi
What is a HPX? |
Originally Posted by 357fhp
Hi
What is a HPX? |
Installing HPX tonight. The instructions say to catch the oil drain off. How much actually runs out from the plug removal?
I don't have any extra oil sitting around. Will I need to get some b4 I start? |
Mine measured in teaspoons.
Insignificant would be the amount involved, but you should have a couple of quarts around for make-up oil, anyway. Mine ride around with me. Pop |
Pop is right. Hardly any ran out when we did ours.
