converting ford lightning shifter to floor
has any one out there ever converted a lightning 2004 to automatic floor shift? if any one has please e-mail
louslightning@aol.com thanks lou. |
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/s...d.php?t=300691 We are happy you have chosen the best source for Fords! Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS! See you on the boards.:-X22 …. |
Welcome aboard!
As you can see the e-mail address has been removed, and clicking the link would explain why. But I also feel it's worth mentioning that we like to keep the discussions on the message boards here vs e-mail so that others may benefit from the information provided. Someone in the future may come along looking to learn the same type of information and could find the thread with our search function (link above). Although I don't know the answer to your question, you may want to look at catalogs from such places as Summit Racing or Jegs to see if you can find the type of product you're looking for - then call or find out if they make that product to fit your application. Good luck! |
Gonna have to be custom built. Have found some examples that it could be done though.
Here is a prerunner bronco with an E4OD on ebay with a floor shifter. Appears to be out of an International truck. http://cgi.ebay.com/ebaymotors/ws/eB...tem=4598512577 Pic here... http://i32.photobucket.com/albums/d1...runner/158.jpg Not only do you have to figure out a linkage, you have to provide for the OD lockout switch wiring. Adrianspeeder |
Darren Pellecchia of Austin, TX has built the most awesome floor shifter/console setup I've ever seen in a Lightning. It was not cheap or easy to do, but the end results are priceless.
[IMG]gallery/spectre/559823.jpg[/IMG] Darren has an article posted on the Ford Truck World website that might provide more insight as to what you could expect to encounter if you wanted to build your own. Article is here. |
http://cgi.ebay.com/ebaymotors/Ford...sspagenameZWDVW
check this truck out it is on ebay, but it has a cool floor shifter. |
