Deleting road draft tube
I posted about this previously,just couldn't find the info again.Someone posted info and a photo of what they did to delete the road draft tube on a 292 y-block.They had included the photo of the installation and the NAPA(I think)part numbers for the proper pcv valve and grommet to fit in the valley pan.I believe they may have mentioned how to block off the hole for the road draft tube.It was a real nice installation.Since I finally got a nice valley pan,i want to do this ,but of course, cannot find the post.Any help appreciated.Steve.1959 F250
I've done this but it was many years ago and my memory is terrible. If I remember correctly I closed off the draft tube hole with a freeze plug and installed a PCV system. This was on a pre-67 Chevy V8, but the principle should be the same for any engine. The main thing is that if you close off the draft tube you need to make sure those crankcase gases can get out some other way... :)
Vern |
I used a valley pan that didn't have the the hole in it or the spash shield. So I welded in a splash shield, bought a PCV valve and grommet for a mustang 302 drilled the hole and installed valve and grommet.
I just made a plate and gasket then replaced the downdraft tube with these items. It's worked fine for the last two years on my 256 cu in 54 merc car |
I posted that back about a year ago. It might take some time to dig it up and repost but I will if needed.
no roaddraft, himmelberg |
Is this the post you are remembering?
https://www.ford-trucks.com/forums/s...ighlight=draft |
That's the one Willy... and here are the pics:
https://www.ford-trucks.com/user_gal...oid=95866&.jpg This is where I cut to be able to bolt it back stock style. https://www.ford-trucks.com/user_gal...oid=95867&.jpg Cleaning up the hole for the brass tube. https://www.ford-trucks.com/user_gal...oid=95868&.jpg Tube in place. Bent a piece of aluminum at right angles, scribe, trim and JB weld the whole thing together. Hey, thank Roger for this method... it is my take on what he did. best, himmelberg |
Thanks for the replys.Your draft tube looks different than the one on my truck.Mine has a hose that goes from a tube on the base of the carb to the top of draft tube.The post I am recalling just removed the entire draft tube and had some kind of a block off plate.Then,he installed a pcv/grommet( in the new valley pan that has the correct hole with an internal baffle plate) and rerouted the hose from the carb base to the pcv.Anyone have photos of this setup or recall the post?Steve
found the post!
It was by 46YBlock,from back in july of 2003.Grommet is HELP brand,part number 42054.Pcv is Deutsche brand, part number PCV134.Now all I need to do is find out where i can find a carb spacer for the two barrel holley that has the vacuum port.Mine is falling apart.Anyone know of a source?
I removed the draft tube from the round part that bolts to the valley pan. It took a little doing, you have to crush the end of the draft tube on the inside so it will come out of the round part that bolts to the valley pan. Then I took the round part to the part store and found a PCV and rubber grommet that fit into the hole previously occupied by the draft tube. Took them home and bolted it on. Total cost less than $6, including the hose to the carb.
One important thing is you need a vent somewhere. I installed a vented oil fill cap. |
