Grease- what brand is the best ??
I m sure most of you aware that 04/05 F150 has some issue with slip yoke (shudder on take off only) and there is a TSB for it.
I had a little issue with my truck FX4 04 shudder on only take off straight. My rearend limit slip already has replaced the clutch and its all good! I decieded try it myself, i removed driveshaft, used regular Valvoline grease and applied it and it works as smooth for approx 4 weeks then it start slowly came back.... So i ordered Teflon grease thru Ford dealer part dept that they use it for TSB and i applied it and its sad to report, it only last 17 days :eek: ! Soo do you have any suggest BEST grease that doesnt dissolve quick and best last longer ?? I havent try mobil one grease... ANy feedback? Thanks! YOMAN! FX4 04 Screw |
I vote for Chevron Delo #2 grease! :-X22
umm ok i ll try find me one then.. is it last longer or you have experneice with it?
Thanks! YOMAN! |
try a local farm a fleet store. they will have all the industrial grease not sold in parts stores. the delo grese is a good grease.
I don't know what's best for your application, but I've used Mobil synthetic in my boat trailer for about 20,000 miles in the water lots. If I understand correctly, the sythetic grease handles high temps much better than most dino grease. I had one set of the disc brakes stuck and get VERY hot. I wet my finger and touched the hub and it sizzled like a hot frypan. The bearings were fine when it all cooled down, but I did shoot new grease in 'em. If regular grease will do that, great, but I don't want it to be my trailer you see on the shoulder propped up with a cinder block.
For the slip yoke, use a CV joint grease.
