Help, Dented, stuck oil filter, ok to drive to shop?
I cant get my dang oil filter off, the shop will switch it for another one for six bucks, its about 15 miles away, will i be ok to drive it there, its holding up alright. hand tight from now on lol.
As long as it's holding and it's just got a dent or two, not totally crushed, you should be fine.
thats about what i thought
do you have the oil filter wrench? i have always been able to get them off with that. if not leaking alright to drive but i think you should try one more time, heck a 17 year old oil pan jockey is going to do what you cannot do, why?
thats what dented it.
Oh and btw im 15 years old lol. |
on your next oil change make sure and use petroleum jelly on the rubber seal instead of oil. That will help in removal as oil tends to become a glue. Make sure and follow the follow the manufactures oil filter installation instructions. I believe that they mostly will say 3/4 to 1 full turn more after the seal contacts the metal surface. I have the strap type filter wrench and a Craftsman large adjustable set of plyers that I can take off 99.9% of all my filters when I worked at the Ford dealership.
Oh and btw im 15 years old lol. thanks for the laughs! |
I need someone 25+ years old to go wit me, thats all.
really, i want you to go try for me, one more time. i know you can do it. heck you are just waiting around for someone to drive you! :-X20 |
alright, fourth times the charm. maybe this time i'll have oil on me up to my shoulders lol.
Managed to bend my oil wrench, and further dent my oil filter.
darn! i wish i was there to help. let me think for a second if i can come up with a solution.
well, There is one of two possible solutions..
a) Drive it to the shop like you mentioned above and pay to have them remove it. b) find yourself a long screwdriver and a hammmer (also mantionaed above). Pound the screwdriver through the oil Filter (in one side and out the other) and use the screwdriver as a handle to turn the filter. It will definitely come off that way (unless there is a strength issue) :-hair the only problem with "b" is that once you do that, it is NOT driveable, so Option A will no longer be an option unless tyou have it towed. |
ive heard all option b does is rip the casing apart.
I've personally done it before... it works
