pics of my ccv mod
ok guys... here's one pic of the ccv mod i did on my mule... all the other pics are in my gallery https://www.ford-trucks.com/user_gal...&albumid=17018
https://www.ford-trucks.com/user_gal.../82619.520.390 |
Good job!
So you used a PCV pipe instead of the stock connector. I see you tied the hose to where the stock center piece used to be. Any obnoxious odor in the cab running that short a hose? |
That's a great idea using the pvc instead of the factory plastic piece in the middle. I sawed the periscope off but the bulge is still there. Hmmm, I know my next project! Make it nice and smooth all the way to the turbo.
I would be interested to know if it lowers the EGTs. Those are hot gasses coming out of the engine.
I just made a bid on ebay on one of the powder coated kits. Don't bid on it until I win the bid tomorrow. I'm the only bidder. |
I used a piece of 4" straight exhaust pipe when I did the mod, rather than PVC. Thought about PVC, but went with the metal instead. I knew I'd have no worries of plastic cracking (PVC can become brittle with age and heat) and letting in a bunch of dirty air to my turbo. The exhaust pipe fit right in place and I re-used the clamps that were on the stock intake tube.
https://www.ford-trucks.com/user_gal...oid=80649&.jpg[/img]Notice 4" stainless exhaust piece.
Thanks for the pictures Johnny. Nice job! Whats the smell like with it dumping right under the front end?
I have an extra piece of exhaust tubing left over from when I did my 6637 filter, that will work perfect. Now to get some tubing. |
Originally Posted by Hello
Good job!
I made the intake modification and after reading many posts regarding heat, I reinstalled the intake portion of my stock airbox. (95 PSD) It routes air right to the filter. Figured it cant hurt to try it out.
I just made a bid on ebay on one of the powder coated kits. Don't bid on it until I win the bid tomorrow. I'm the only bidder. Ow gee, sorry bout that! :-X14 |
Johnny, I can't believe I beat you to a mod.
You must'a been outta' town for a few days! I turned my hose downward and dumped it near the wheel well outside the frame, no fumes, in fact very little smoke coming out. It does have decent pressure blowing out though. I want to use a one-piece instead of the current setup with the hose. (in gallery) |
