Wires
Can Spark Plug Wires Be Touching,together Or Will This Effect Anything If They Are Touching Together. Just Trying To Clear Something Up.
On an engine with the
1 5 4 6 3 2 7 8 firing orders the #7 wire & the #8 wire should be separated by the plastic spacers mid-harness & on the valve cover. On the valve cover seperator they should be from front to back #5 #7 # 6 #8 Reason: Once wires go bad they can arc over & create a cross-firing engine. http://www.nightrider.com/biketech/truth.htm |
