What oil filter and how much oil for 302
I wanna do a oil change on my truck, what filter do i need to ask for and how many quarts do i need? i think its 5?
your 302 takes 6 qts with filter change and an FL-1a filter (motorcraft :-X22 )
Thanks, off to pep boys i go!8D
-Matt :-tap |
oil and filter
The weezle votes for 6 quarts of motocraft 10 w 30 and a motocraft filter
all that goes into my f 150 5000 miles on the new engine and it runs excellent |
10W30 is too light for Southern US states. 20W50 - in my case, Valvoline MaxLife 20W50 for my 265,000 mile F-150.
engine sure dose take alot of oil!
for future refrence, is there a way to get the oil filter out without spilling oil onto the front diff and the cross member thing thats right under it? it got prety messy there. |
Oil spills
Throw a newspaper across the axle and one under. Really no other way except to get the remote filter kit.
James |
Go to Costco and get the mobil 1. It will help extend your motor life... If you dont have a Costco near you themit will cost more but still worth it... And i use WIX filters....
302 Oil Change
6-qts of Quaker State 10W-40 & a Fram PH8A Oil Filter !!!
Havnt heard many good things about Fram. I put a motorcraft one in, it was real cheap too.
What sort of things have you heard about Fram? I'm asking 'cause I just put one in the truck and the car recently. I never used Fram before this either, it was just what I happened to pick up. |
Do a search in the Oil and Lube forum. Be scared! :-hair
-Matt :-tap EDIT: I did it for you! :) https://www.ford-trucks.com/forums/s...earchid=342848 |
Thanks, Beast12. Needless to say, the next oil change will be including a different brand filter.
and never use quakerstate or fram it is junk
