Stainless Steel Duel rear Side Exit Exhaust?
Does anyone know of a manufacturer for my SCREW that makes a cat back duel exhaust system that is stainless steel that duel exits out both sides behind the rear wheels, Borla, Bassani and Magnaflow make a duel system but only split at the rear of the truck. THANKS!
T |
Actually, I don't think srq is looking for a true dual setup. He just wants the pipes to exit to the side behind each wheel instead of directly out the back. Now, I could be wrong (it's happened before), but the only stainless steel (SS) kit I know of is sold by Borla ... and it exits straight out the back (I have it). I've seen a couple of behind the wheel exit jobs, but doubt they were all SS. For that, you may need to get a muffler shop to do a custom job for you. I'm 99.9% sure that's the route you'll have to go for what you want.
Thanks for both ofyour responses, actually Gordo I was thinking the same as you on this, I'll keep looking, but I know Borla is top notch having using them before, maybe I'll just go split out the rear, Thanks!
JBA exhaust has it in stainless
jbaheaders.com if the link below gets cut off http://www.jbaheaders.com/04f150new.asp -aaron |
Gibson makes a ss kit that exits behind each rear wheel BUT!!! it will not fit a FX4. I found this out the hard way. I ordered it and tried to install it. IT would not fit. So I called Gibson and they said it would not fit a FX4 because of Different exhaust hangers and crossmembers on the FX4. If your truck is not a FX4 this is a nice system. Its called, Gibson Dual-Extreme Stainless Cat Back Part#Gib-69007
