Stainless Steel Duel rear Side Exit Exhaust?
Does anyone know of a manufacturer for my SCREW that makes a cat back duel exhaust system that is stainless steel that duel exits out both sides behind the rear wheels, Borla, Bassani and Magnaflow make a duel system but only split at the rear of the truck. THANKS!
T
Actually, I don't think srq is looking for a true dual setup. He just wants the pipes to exit to the side behind each wheel instead of directly out the back. Now, I could be wrong (it's happened before), but the only stainless steel (SS) kit I know of is sold by Borla ... and it exits straight out the back (I have it). I've seen a couple of behind the wheel exit jobs, but doubt they were all SS. For that, you may need to get a muffler shop to do a custom job for you. I'm 99.9% sure that's the route you'll have to go for what you want.
JBA exhaust has it in stainless
jbaheaders.com if the link below gets cut off
http://www.jbaheaders.com/04f150new.asp
-aaron
-aaron
Gibson makes a ss kit that exits behind each rear wheel BUT!!! it will not fit a FX4. I found this out the hard way. I ordered it and tried to install it. IT would not fit. So I called Gibson and they said it would not fit a FX4 because of Different exhaust hangers and crossmembers on the FX4. If your truck is not a FX4 this is a nice system. Its called, Gibson Dual-Extreme Stainless Cat Back Part#Gib-69007
