Heater...IN and OUT
Ok, well my heater has been acting up, it will be fine one minute, then all the sudden it will go cold. I have to turn it off, then back on for it to be right again. What is going on?
thermostat needs replaced man. I had the same problem in one of my cars once.
Is that what it is? Any other advice?? Im gonna go check the thermostat.
$5 0r $6 will solve your problem you can't go wrong.
Well.....found that part. A whole $2.99!!
make sure you get the gasket and drain a little coolant out before you replace the thermostat. Spring towards the engine block on the thermostat.
