Ground wire issue?
Recently I just had my sparkplugs replaced and the car(ford explorer 2006-10?) ran well for a week but then the electric features of the car went faulty until the car wouldnt start at all and drained the battery. what do you think caused this? i checked the engine for any loose wires or anything like that and saw one of the ignition coil( im not sure if that is what the part is called) is disconnected.
im new please dont judge. https://cimg9.ibsrv.net/gimg/www.for...44323799b.jpeg |
Charge the battery up with a small charger. It will usually take all day and one night to get it topped off with a small charger. While doing that you may find the battery is bad. The charger may tell you, or once it's charged up, you can carry the battery into the store and they can load test it for you.
If the battery passes, then get one of those battery terminal cleaners like the one below. It's made to clean the outside of the battery terminals and the inside of the cable ends. It's a good tool that will last you your lifetime. Clean the terminals on the cables and the battery and hook it all up and then see what happens. |
(Post 21211830)
If the battery passes, then get one of those battery terminal cleaners like the one below. It's made to clean the outside of the battery terminals and the inside of the cable ends. It's a good tool that will last you your lifetime. Clean the terminals on the cables and the battery and hook it all up and then see what happens. https://www.amazon.com/Schumacher-BA...060YHP62&psc=1 alright ill test it out. though my father said that it would be impossible for the battery to be faulty or finished because we had just changed it. we changed it on september last year he said and he also said that it was too early for it to already be finished/drained. do you think this is true? |
usually that would by true, but i have also seen bad batteries that are less than one year old.
Originally Posted by ilhaze
(Post 21211848)
i would more suspect a bad alternator than a bad battery.
(Post 21211848)
Each cell in your battery is a shade over 2 volts. That's why 12 volt batteries, with caps, have 6 cap and 6 volt batteries have three. If you check it with a volt meter and get 10 volts, you may have either a dead cell or bad internal connection. If it's charged and you check it, you should get around 12.4 to 12.8 volts at rest. While I generally just use a volt/ohm meter, I did spring for a fancy computerized job that tests the battery and the charging system. I hate to admit it, but it's a lot faster than I can do the way I was trained. Have you changed anything like a different radio? After a week and then it starts draining the power sounds like a switch not shutting off. Like the interior lamps or something. |
Originally Posted by tjc transport
(Post 21212909)
Originally Posted by Ol' Grouch
(Post 21216368)
UPDATE
we replaced the battery with another one and it runs fine, but im kind skeptical about it as it might drain this battery as well.
https://cimg5.ibsrv.net/gimg/www.for...83daa1e363.jpg |
replacing the battery may not have fixed it. what is voltage at battery with engine running?
(Post 21217867)
a volt meter, across the battery terminals
(Post 21217911)
(Post 21217915)
alright ill look up where to buy volt meters. i have a question tho, can ground faults really drain the battery of the car? i just checked the car for anything faulty in the electrical systems everything seems to be running well. but ofcourse i wont use the car until I get a proper way of knwing if the car is grounded or not
Here's one with a decent rating. https://www.harborfreight.com/electr...ity-59410.html I would buy one of these too. Very useful to help find a drain if you happen to have one, plus other things on a car or truck. https://www.harborfreight.com/electr...ead-63603.html |
