B&W Companion RVK3300 doesn't fit into OEM pucks
I just picked up my new 2024 F-350 Lariat CCLB SRW today. I got it with the OEM 5th wheel hitch prep and bought a new B&W Companion RVK3300. I can't for the life of me get the B&W base to fit into all 4 pucks at the same time. On the passenger side I can get the B&W base to drop into the the front or back puck, but not both at the same time. Because I can't get the base to fully seat I can't get the castle nut on the corner that won't seat tightened enough to insert the cotter pin. The driver's side is fine. The pucks on the passenger side measure about 1mm closer together than the driver's side. If I rotate the B&W base 180 degrees the problem seems to stay on the passenger side. There's no way to adjust the spacing of the B&W base corners or pucks. I'm trying to figure out if this is an issue with the B&W base or Ford hitch prep bracket. I could file either of them down to force a fit, but that doesn't seem right or safe.
https://cimg3.ibsrv.net/gimg/www.for...656f064ece.jpg |
Something seems off. As you state it doesn’t follow the hitch, but stays with the passenger side.
So I’m thinking it’s the mount that’s off. Not sure if this helps, but there are some installations videos and some FAQ,s B&W Companion Hitch |
I watched a video and it showed adjusting the feet for this reason. I’m not sure the newer Companions are capable of that. I would call BW and ask them.
Originally Posted by Member No. 1
(Post 21203025)
Originally Posted by Erie660
(Post 21203054)
1mm is causing the problem?
That's seems like a pretty tight tolerance. Did you try the passenger side first? |
Originally Posted by longhaultransport
(Post 21203307)
This has happened before.
Read the posts of FTE Member @1ROBBANKS1 2023 F-350 puck system not aligned Ford puck problem... not aligned, not spaced properly... repaired by Ford under warranty There are also other threads on FTE with additional members reporting similar issues. One thread shows photos of a puck alignment measuring device used by dealers. The fact that such measurement jigs are in circulation among dealership service departments is an indication that your issue is not isolated, and despite the Ford OEM hitch prep being a monolithic weldment installed at the factory, there have been problems reported within the last 3 years, including a recall in 2021, that did not seem to be evident in the previous decade of this puck system. |
Originally Posted by Y2KW57
(Post 21203403)
I would use a die grinder so it fits.
But, that's just me, different strokes and all that. |
(Post 21203490)
I would use a die grinder so it fits..
If there is a potential that it was mis-manufactured, the time to address it is immediately, while still brand new, as soon as the issue is discovered. Grinding the truck pucks or the B&W hitch would likely shift the burden of liability to the person who did the grinding, which would be classified as "cutting". Most manufacturers include stickers on their hitches that state "Do not cut, drill, or weld." The area of actual engagement between the pucks and rotating cleats is quite small. The small amount of material removed by grinding might still represent a measurable reduction, relatively speaking, of the already small concentration of contact area. For between $70K to $120K, the Ford puck system should be manufactured and installed to the standard that Reese specified for the puck system, which is the same standard that third party hitch manufacturers rely upon to assure interchange. If the OP were to grind the B&W to make it fit a misaligned Ford hitch, what happens when the OP wants to upgrade to a Trailer Saver Air Ride hitch.? He would have to grind that too, and so on. If the problem is with Ford's manufacturing or factory installation gone slightly awry, the problem should be corrected by Ford, so that the OP can use any hitch designed for the puck system without cutting, drilling, welding, or modifying to make fit. |
I just dropped the exact same hitch onto my 2024 limited. No problems.
I would not let 1mm scare me into tying my truck up for who knows how long, waiting for Ford to fix it.
Like I said, that's just me. |
(Post 21203559)
The OP just picked up a brand new 2024 vehicle that likely cost very near $100,000.00.
If there is a potential that it was mis-manufactured, the time to address it is immediately, while still brand new, as soon as the issue is discovered. Grinding the truck pucks or the B&W hitch would likely shift the burden of liability to the person who did the grinding, which would be classified as "cutting". Most manufacturers include stickers on their hitches that state "Do not cut, drill, or weld." The area of actual engagement between the pucks and rotating cleats is quite small. The small amount of material removed by grinding might still represent a measurable reduction, relatively speaking, of the already small concentration of contact area. For between $70K to $120K, the Ford puck system should be manufactured and installed to the standard that Reese specified for the puck system, which is the same standard that third party hitch manufacturers rely upon to assure interchange. If the OP were to grind the B&W to make it fit a misaligned Ford hitch, what happens when the OP wants to upgrade to a Trailer Saver Air Ride hitch.? He would have to grind that too, and so on. If the problem is with Ford's manufacturing or factory installation gone slightly awry, the problem should be corrected by Ford, so that the OP can use any hitch designed for the puck system without cutting, drilling, welding, or modifying to make fit. I called B&W this morning and they said there has recently been two other Super Duties with puck alignment issues. Both built in March 2024. My truck was built somewhere between 2/22/24 and 3,/10/24. The long timeframe is because it got hung up with the February IPMA firmware issue. The guy from B&W said on the March trucks that the driver's side front puck is too low and they provided shims to fix it. I'm not sure if I have the same issue as on my truck it appears to the naked eye that the passenger rear puck is slightly cattywampus. I had my local B&W trailer shop with tons of hitch experience look at the issue as well. They had never seen such a thing, but concluded the rear passenger puck appeared tilted and no amount twisting and titling would fix it. B&W is sending me shims that will take 3-4 days to arrive and I'm at the dealership stepping on their nuts about the issue today. I'll update once I have a resolution, as it sounds like there may be some other folks that will soon encounter this. |
Out of curiosity do you think a different brand may fit your pucs?
DA |
